1976 carrera
cis from 76 2.7 to cis from SC?
Hi all,
I have a 76 911s with 2.7 and standard cis system, I got a another cis from an sc car,
is it any different ?, will the sc cis improve my car ?
thanks
Gilad
Old 05-06-2014, 12:00 PM
Dave Colangelo's Avatar
Not sure if they are different but they sure do look the same in pics. And I know I have a 2.7 air box cover on my 3.0 engine and it is the same size so I will assume that they are generally the same. What I will say is that you will most likely benefit from a proper tuned 2.7 CIS system more than you will by slapping on what may be a slightly bigger (if anything) CIS system from a 3.0.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 05-06-2014, 12:07 PM
There was a small change in the big rubber boot found on the top of the engine between the 1974 model and the 1977 model. An extra port or nipple on the back of the 1974.
I would imagine even greater differences between a mid-year and an SC in other areas.
Old 05-06-2014, 12:08 PM
ROW '78 911 Targa
timmy2's Avatar
78, 79 and euro cars have larger intake runners. 74-77 and the US 80-83 have the same intake runners.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-06-2014, 12:44 PM
What specific SC model/year?
Originally Posted by giladblum View Post
Hi all,
thanks
Gilad
Gilad,
There are three (3) distinct groups of SC CIS components for USA/Canada models. They are the '78-'79, '80, and '81-'83 excluding the Euro or RoW cars. Installing the later SC CIS components in your '76 will not improve or enhance anything except your ego!!!!
What are your incentives in attempting to do a mixed matched set-up? While it could be done to assemble such concept, you are simply making the maintenance and troubleshooting more complicated that the standard set-up.
Well, the decision is all yours. If you are the type of individual who prefers challenge, pressure, and going against conventional wisdom go ahead and find out yourself. And keep us posted.
Tony
Old 05-06-2014, 01:02 PM
Hi all,
thanks
Gilad
Question is, what year SC is it from? If from an 80 or later, you'll need to add the 02 sensor and ECM or it won't run right.
Old 05-06-2014, 01:16 PM
1976 carrera
Originally Posted by boyt911sc View Post
Gilad,
Tony
Hi Tony and all,
Thanks for your words, I do have an issue with my ego but I understand that this is Not the place to deal with it (-:
I am looking to get better performance from my car , now I see that the CIS is not The place to get it,
thanks for all replays
Gilad
Old 05-06-2014, 08:51 PM
T77911S's Avatar
the only thing you can do is put the throttle body from the SC on the your 2.7. you will have to remove the decel circuit and run without one.
the TB from the SC is much bigger than the 2.7. this will only make a difference at WOT.
other than that there is no advantage. in fact, if the SC system you have is a lambda system, yours is more reliable, no electronics. the 78-79 will only help if you have big HP.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-07-2014, 03:57 AM
