kodioneill's Avatar
suspension handling issues after upgrade
Vehicle: 1985 Carrera 109,000 miles
New tires front 205/55/15
rear 225/50/15
set to euro height
installed the following:
bump steer kit
turbo tie rods
ball joints
control arm and sway bar bushings poly flex
new rear standard spring plate bushings
new rear sway bar bushings
new hd bilstein front strut inserts
new bilstein rear hd shocks
corner balance and alignment
new polyflex strut bushings
alignment rear 1.5 deg camber no toe
front .50 deg camber 6 deg caster 10' toe in
complaint: the car handles better around sweeping turns as long as I don't over-steer but floats at higher speeds.
It feels like a boat in water, slow to respond and it feels like if I over correct I might loose control. You know how racers warm up their tires at the beginning of an event by weaving back and forth? This car is slow to respond and not sharp for lack of a better term feels like I'm in sand. My friends 77 with no mods feels tighter.
thanks for any help.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-21-2014, 12:26 PM
kodioneill's Avatar
Complementary photos
1982 chiffon 911sc
Old 05-21-2014, 12:45 PM
Make America Great Again!
Rich Gas's Avatar
Very nice...tire pressure ?
Old 05-21-2014, 12:59 PM
kodioneill's Avatar
As per factory 34 rear 29 front I believe. You know, a good explanation of the feel I'm getting is just like too little tire pressure.
1982 chiffon 911sc
Old 05-21-2014, 01:06 PM
you should have a little bit of "toe in" in the rear for most street driving. It will make the car feel more stable. Front toe can be at Zero for some better response. But I think most of the time factory toe in is best
2006 Cayman S
93 RS America white(now living in Arizona)
1974 911S/CARRERA (now living in Australia)
Livermore Ca.
Old 05-21-2014, 01:09 PM
rkeele's Avatar
what about your front shock inserts? you mention new rears, maybe the fronts are bad that would cause that kind of feeling.
Old 05-21-2014, 01:37 PM
kodioneill's Avatar
Thanks but they're new bilstein heavy duty inserts.
1982 chiffon 911sc
Old 05-21-2014, 01:44 PM
joe payne's Avatar
Don't forget your friends 77 probably weighs less too. Less weight, less roll.
jtp911
Old 05-21-2014, 01:48 PM
kodioneill's Avatar
Thanks Joe I know, but this is strange it feels as-though when turning at a good rate of speed if I turn the wheel a little extra I'll lose control of the car.
I have a real heavy Solara and it handles like a rat in a sewer pipe.
1982 chiffon 911sc
Old 05-21-2014, 01:55 PM
toddu's Avatar
Directional tread?
Todd
'81 SC
Old 05-21-2014, 02:00 PM
kodioneill's Avatar
Originally Posted by toddu View Post
Directional tread?
Todd
Yes
1982 chiffon 911sc
Old 05-21-2014, 02:06 PM
abit off center
cgarr's Avatar
I know wrong toe in the rear mostly if toed out will make the rear feel like you have a flat tire.
______________________
Craig
G2Performance
Old 05-21-2014, 02:10 PM
redridge's Avatar
check steering rack for play... when you turn the steering wheel (even a little) do you see the wheels respond?
Old 05-21-2014, 04:04 PM
moneymanager's Avatar
What is the bump steer kit? The two washers at the steering rack, or the more elaborate product? The latter made my 74, set slightly lower than your's, into an unresponsive but dangerous feeling beast.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 05-21-2014, 04:10 PM
kodioneill's Avatar
Yes the rack responds with a small amount of effort it seems very responsive.
1982 chiffon 911sc
Old 05-21-2014, 04:34 PM
kodioneill's Avatar
The bump steer kit is the two washers. Are you saying I should remove said kit?
1982 chiffon 911sc
Old 05-21-2014, 04:36 PM
pete3799's Avatar
Pull some strings on it. Could be they messed up the alignment.
Pete
79 911SC RoW
Old 05-21-2014, 04:50 PM
Max Sluiter
Flieger's Avatar
I would try some toe-in at the rear.
Old 05-21-2014, 05:14 PM
Re bump steer washers... no, don't remove. I think you've done the right thing. There is a much more expensive variation from Rebel, Elephant and others which can produce bizarre results unless you really know what you are doing and have lowered the car a good deal more than you have. I doubt the washers are your problem. In fact I doubt that any of the hardware changes you made have anything to do with your symptoms. I'll bet it's all in the setup, somewhere.
jhtaylor
santa barbara
Old 05-21-2014, 05:40 PM
Max Sluiter
Flieger's Avatar
The more expensive version is meant only for cars with raised spindles.
Old 05-21-2014, 05:45 PM
