Uncle Enzo's Avatar
She just cuts out. No warning. Please advise
76 2.7 running webers. Took her out for a spin yesterday as it was perfect. Outside temp was about 80 oil temp a shade below 200f. After about an hour of spirited driving the car just shuts down with the tach bouncing all over.
. I ghost ride it to a safe spot, get out and check out all the connections and all looks ok. Fuel pump is running and the car cranks. I wait a few min and it roars back to life and since I'm 3 miles from home I gun it and go. It then dies a mile at the next light. I wait a few min and it comes back to life and I make it home. Once home I try and to get it to crap out with no success.
From what I've read it sounds like a failing CDI. If you
Have any other ideas let me know. Since I can't replicate it makes it difficult to diagnose.
Old 05-25-2014, 07:03 AM
Cdi.......
What brand CDI you have now installed? Next time you happen to experience this problem again, check if you have ignition sparks. The problem seems to be temperature related. Keep us posted.
Tony
Old 05-25-2014, 07:10 AM
4flyboy's Avatar
For what it's worth.......I had precisely the same symptoms on a ride to Vegas one weekend. Wire between the distributor cap and the coil was broken inside.
Mechanic in Baker pulled one off a junked VW bug and sent me on my way in 5 minutes. Luckiest, easiest temporary fix I've ever had. Saved a great weekend too.
Best of luck,
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 05-25-2014, 07:14 AM
Uncle Enzo's Avatar
I'm running a Bosch 3 plug unit. Looks orig.
Old 05-25-2014, 07:16 AM
Vintage Owner
Jack Stands's Avatar
Definitely sounds like an ignition problem when hot. Usually, if you hear the Bosch CD humming, it's working ok. I'd also consider a bad wire or connection as a possibility, but these intermittent problems are sometimes tough to find.
There has been a lot of discussion on various ignition systems to replace the Bosch unit, and there are folks that are repairing these units as well.
Hope you find the source of the problem so you can continue to enjoy the ride!
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 05-25-2014, 07:25 AM
ROW '78 911 Targa
timmy2's Avatar
Check your fuel pump fuse for corrosion and the terminals are tight. Also check the fuel pump relay is good and tight.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-25-2014, 07:31 AM
Uncle Enzo's Avatar
Check all the fuses and relay. All checks out fine. I've had a fp relay poop out before and this was far more abrupt. Just shut down. No warning.
Old 05-25-2014, 07:34 AM
non-whiner
mreid's Avatar
Classic coil problem.
"Too much is just enough."
Old 05-25-2014, 07:42 AM
El Duderino
tirwin's Avatar
Agree with others here. Sounds like ignition box or coil. Seems like there has been a rash of these lately.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 05-25-2014, 08:21 AM
al lkosmal's Avatar
+1 on the coil.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-25-2014, 09:02 AM
Uncle Enzo's Avatar
Any recommendations on a coil as the Bosch unit seems to get poor reviews.
Old 05-25-2014, 09:22 AM
al lkosmal's Avatar
MSD High Vibration Blaster Coil.
http://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_ELIGNT_pg4.htm#item8
Al
RGruppe #669
Old 05-25-2014, 09:40 AM
Uncle Enzo's Avatar
Thanks,Al!
And the price it right.
1976 911S
MidYear Fever is alive and well.
Old 05-25-2014, 02:29 PM
wwest's Avatar
Alternator stator winding is shorting out intermittently, EMI couples to CDI results in random plug firing, tach jumps, hits rev-limit, rev-limit locks up...
Recovery...switch off, count to 10 slowly, restart..
Old 05-25-2014, 04:13 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Once it stalls, don't turn the ignition off but open the engine lid and listen to the CDI. If the hum is higher in pitch and fainter it confirms the CDI box is failing. It latches up. This typically happens at high temperatures. Once you power-cycle the box (turn ign off the on) the hum returns back to normal @ 3.5kHz. Depending on how long you wait before driving again the box cools down somewhat and will work for another couple of minutes before the cycle repeats.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-25-2014, 05:23 PM
Uncle Enzo's Avatar
God, I love this place. Thanks for all the great intel, fellas.
Old 05-25-2014, 06:20 PM
47silver's Avatar
Had the same problem the wire inside the distributor would touch the distributor cam when the engine was warm. I found it when I installed a pertronix ignitor
Old 05-26-2014, 06:14 PM
