SMHemmah
hemmah's Avatar
Turn signals don't work
I have a 1969 911T and my turn signals don't work. My emergency flashers work. All other lights work. The high beam switch works.
Is the solenoid (or other delay time switch) for the turn signal the same solenoid for the emergency flashers?
What do you think is the problem with the turn signals?
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank
Old 05-31-2014, 08:45 PM
Send a message via Skype™ to Porboynz
Check fuses and turn signal relay, its located behind the fuel/oil level gauges. Start by reseating it, then replace it. (or you can pry it open and investigate) Its a rectangular black plastic relay. Search on "Relay Identification on a 69T"
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-31-2014, 09:09 PM
bavaria911's Avatar
My 1970 did the same thing three years ago. I just opened the hood and removed every fuze cleaned the ends and the fuze box ends, sure enough the turn signals worked and ever since.
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 06-01-2014, 06:54 PM
SMHemmah
hemmah's Avatar
Thanks All. I have some contact cleaning to do. Now I know what relays are what function.
Old 06-02-2014, 08:29 AM
