Threads
I've heard lots of different opinions on what the minimum threshold for a safely engaged wheel nut consists of, but I'd like to hear more ...
I'm trying to fit a new set of rear wheels with a massive 335 section Hoosier on my track/race 911, but they require 25mm spacers - leaving 10 complete turns of thread engagement on the steel wheel nuts. But that's only about 1/2 of the nut itself. Would you run it? In the near short term I will change the wheel stud length, but don't have the time before next weekend. What say you? Sent from my iPhone using Tapatalk
78 911 Coupe :: E Prepared racecar :: Stock 3.0 :: Steel widebody :: 930 brakes 78 911 Targa RSR backdate :: 3.2L :: 10.5:1 Wossner pistons / Mahle cylinders :: Twin plug crankfire ignition :: 46mm PMO |
Sounds like a bit weak to me. General rule is 1.5 x diameter gives max possible for a thread, more does nothing (on equal material of both) If in your case the 10 turns are 1.5 of the diameter, you'll be fine
Roland 930 Turbo '81 Too many modifications to list |
1.5x the diameter of the nut?
I'm not sure the height is even equal to the diameter (i.e the height of the nut is smaller than it is across or at the least, they're equal) Sent from my iPhone using Tapatalk
Caveman Hammer Mechanic
Aircraft world, minimum one thread exposed. Lots of dynamic forces on wheel studs, really wanna take a chance with minimum engagement? Imagine the consequences of the wheel coming off in a 3rd gear, full throttle sweeper at redline, then ask if you want to try it on for size....
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Are you planning a track event ?
Many organizations require three extra threads showing |
Bolt diameter.
Example: For a M14x1.5 it's 21mm which reaches max. strength. Less is weaker, more does not add more
This seems to be pretty standard from the PCA rule book, AX guidance, etc.:
Wheel nut or bolt must fully engage the threads on the stud or hub for a length at least equal to the outside diameter of the wheel stud or bolt. The use of open-ended steel lug nuts is required in all cars with 400 or more Performance Equipment Points where lug nuts and wheel studs are fitted. The use of open-ended steel lug nuts is additionally required on all cars using lug nuts that have non-stock wheel spacers fitted, to allow verification of compliance with this section. Wheels must be torque to specification. Best, Dave
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
83 911 Production Cab #10
In the Navy too...
Quote (Naval Ships' Technical Manual) 075-7.5 LENGTH OF THREAD PROTRUSION 075-7.5.1 MINIMUM THREAD PROTRUSION. A minimum thread protrusion length is given to ensure that all the threads are engaged. This is required to ensure a full-strength fastener. Equipment component drawings should specify the type, length, and size of bolt, stud, bolt-stud, etc. to be used to obtain the proper thread protrusion. If not specified on the drawings, threaded fasteners of commercially stocked lengths should be used. Threaded fasteners, when installed and tightened, should protrude a distance of at least one thread beyond the top of the nut or plastic insert. Excessive protrusion should be avoided, particularly when necessary clearances, accessibility, and safety are important. Thread protrusion is considered excessive if it could cause damage to machinery or harm to personnel. Where practicable, the number of threads protruding should not exceed five. In no case should thread protrusion exceed ten threads. In the case of a stud, excessive thread protrusion may indicate that the stud has not been properly driven in the blind hole. In self-locking nuts where the distance from the top of the nut to the locking element (plastic insert) is equal to or greater than the chamfer, the bolt or stud end may be flush with the top of the nut. For existing or reused fasteners where the thread protrusion exceeds 10 threads, verification should be made that the proper length fastener was installed. For existing installations utilizing standard nuts, acceptable minimum thread protrusion would be where the male thread, below any unthreaded chamfer or crown, is flush with the top of the nut. Washers should not be added to reduce protrusion except as specifically required by equipment component drawings or technical manuals.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Thanks gentlemen
For the record, while I apply the above on my day job, my front rims are about 1 thread short of being flush and I'm not loosing any sleep over it.
abit off center
I would not run it like that:
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
This rule with one turn over the flush is just to see, if one is loose and at lock nuts of course to be "clamped" for sure.
