Alan L's Avatar
If you loose an air injection plug you should hear it clearly at idle (been there).
Since it is there at idle, you should be able to get close to it by jacking the rear of the car up and getting underneath while idling. Even run your hand along close to where the noise seems to be. You should at least be able to identify it to one side or other (unless it is central- fan).
From memory I have had broken studs that did not fall out when valve covers removed. I would suggest a magnetic pick up stuck down each stud hole to see if you pull anything out with it (the nuts are magnetic - but not normal socket type nuts. They are allen key barrel nuts).
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-04-2014, 04:01 PM
RETIRED
Joe Bob's Avatar
Heard that sound as well......head studs......
2012 ML350 3.0 Turbo Diesel
Old 06-04-2014, 04:29 PM
I had a chance to jack it up today and it wasn't the sound of financial doom, but thankfully an air injection plug that had blown out, as TJJ911 suggested.
So I raced to the hardware to see if there is a 10mm bolt with a 1mm pitch, but no one had it, so I'll check out the nuts and bolts shop tomorrow.
From looking at it though I'm not to confident of the threads so I might need to put a time cert / helicoil in there.
Cheers for the help guys.
Old 06-09-2014, 04:13 AM
TJJSC's Avatar
I think ther'se a mercedes part to be used for this (no sure wich one), I applied loctite on al the blocking off plugs, only one failed over time. Cleaned it out again/degreased and applied loctite and... no problems ever since. I can remeber also some of my port threads wera a little doubtfull.
Good luck with the repair!
Old 06-09-2014, 05:16 AM
hex head 1/8" pipe plug. the taper fit locks them in nicely.
206 637 4071
Old 06-09-2014, 07:22 AM
Alan L's Avatar
Or there is a 914 brass plug that has something to do with the brake system from memory.
That is what I used.
Alan
Old 06-09-2014, 12:15 PM
914 rear inside caliper plugs. takes time to order and receive. the pipe plugs are down at your local auto parts store, fastener store, hydraulic store, boat store, etc.
206 637 4071
Old 06-09-2014, 01:28 PM
Fleabit peanut monkey
Bob Kontak's Avatar
TJJSC gets a gold star.
Good news.
1981 911SC Targa
Old 06-09-2014, 03:22 PM
