billwagnon's Avatar
More 73 heat exchanger questions
My car failed inspection due to leaking exhaust - holes in the heat exchangers. The inspection was last August and I can now fix it.
I don't hear any leaking exhaust noise. I think the problem is just the exterior of the exchangers.
The mechanic has a left or right single SSI for sale - I'm not sure which yet. Pelican says they cannot split sets (I can't purchase just the left or just the right) so I am trying to figure out if both of mine are bad.
One of the heat exchangers had a patch job; the patch was detaching so I pulled it off.
My question is about the difference between the two sides.
LEFT has a muffler outlet, and two other outlets. The left has an extra shell around the three pipes where they combine into one for the exhaust and this shell has an unattached opening.
RIGHT has a muffler outlet and one other outlet.
SSIs don't appear to have the extra Left shell and outlet. Left and Right SSI look like mirror images of each other. Is that extra shell and outlet on my left necessary?
Also, here is detail on the Right. Would this leak?
Old 06-12-2014, 11:52 AM
The left heat exchanger for 1972 and 1973 cars equipped with MFI has a port near the heater outlet for the heat riser to the MFI pump, as well as a larger outlet for the heat riser to the hot air box for the air filter. The first is for an adjuster on the back of the pump that alters the mixture as the engine warms up, kind of like a choke. The second one is used to provide warm air to the air filter during warmup, and is a mechanism that's pretty common industry-wide. The emissions books refer to this as a "thermostatic air cleaner". You can live without the second one, but not the first, unless you've done a manual workaround for the temperature compensator (thermostat) on the FI pump.
The Cap'n
Old 06-12-2014, 12:20 PM
billwagnon's Avatar
The car has Webers now so I'm not worried about the MFI port.
What I am talking about is the extra shell and large outlet on the left heat exchanger that is not on the right, and is not apparently on the SSIs either.
Old 06-12-2014, 01:27 PM
The large outlet is the one you can do without. I suggest plugging the smaller outlet with something that can be reversed. That high end shiny silver duct tape (NOT the everyday gray stuff!) should do it. A couple of layers at right angles and a hose clamp.
The Cap'n
Old 06-12-2014, 02:20 PM
billwagnon's Avatar
Heat exchangers successfully removed!
What is the circled part here? I don't see it on any of the SSIs.
Old 06-13-2014, 11:41 AM
tobluforu's Avatar
That connects via a hose to the air intake flapper control unit on mfi cars which some take out as it pretty much does nothing. Kind of like a pre-warm up device that was supposed to help with emissions.
Old 06-13-2014, 12:06 PM
billwagnon's Avatar
thank you!
Old 06-13-2014, 12:10 PM
billwagnon's Avatar
Two or three of the studs came out with the nuts.
The Pelican catalog lists the studs. Should I replace all 12? Should the studs come out of the cylinder head easily?
I am kind of paranoid about breaking them off. The ones in there look okay.
The engine was rebuilt about 30,000 miles ago.
Old 06-13-2014, 01:58 PM
tobluforu's Avatar
Same thing happened to me. I only replaced the ones that came out, but I also doubled nutted each to see if more of the studs would budge, which they did. Left the others in there, up to you. I also used kroil for a few days before I tried.
Old 06-13-2014, 02:05 PM
Just to be clear. The sheet metal around the exh. pipes contain only ambient heated air from the cooling system, not exhaust gases which are inside the individual tubes.
Did the smog tech conclude from a visual inspection that exhaust gases were leaking from the holes in the HE sheet metal or did he sample that area with a CO sniffer? No telling the skill level of various techs.
Sherwood
Old 06-13-2014, 02:53 PM
47silver's Avatar
You want to seal test them so the exhaust does not leak into the heat exchanger as it will pump co into the cabin when you use the heat flapper
Old 06-13-2014, 04:02 PM
Tags
early , heat exchangers , ssi
