Stranger on the Internet
patkeefe's Avatar
Clutch Cable Replacement Issue
Hi All,
I am installing a new clutch cable. I procured this from our hosts at least a year ago, just getting to it now. The cable, specifically the outer cover in the rear, which is exposed under the car, seems too long. If I snug it over the protruding tube on the firewall, the cable is too long to fit into the adjustment anchor notch on the gearbox. I will go take a picture, and post it.
It seems to be the correct cable, a Gemo 424 427. Anyone else had an issue with this?
TIA,
Pat
Patrick E. Keefe
78 SC
Old 06-15-2014, 06:55 AM
patkeefe's Avatar
Photo:
Patrick E. Keefe
78 SC
Old 06-15-2014, 07:04 AM
Looks right to me. I would unhook the clutch lever end then attach the part in the trans , a washer and nut on either side of the slotted flange. Then hook the clutch lever end and adjust as needed.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-15-2014, 07:11 AM
patkeefe's Avatar
Thanks, John. I hooked the cable onto the lever to hold it while I took the photo. I can't get the cable to push forward enough to attach it. The firewall end is seated.
Patrick E. Keefe
78 SC
Old 06-15-2014, 07:17 AM
Not sure why because the cable should bend/flex to allow it to drop in.
1995 993 coupe
2012 Boss 302
Old 06-15-2014, 07:49 AM
patkeefe's Avatar
John, should the cable route above or below the cantilevered throttle bellcrank rod mounted on the transmission? It doesn't look quite right above the rod.
Patrick E. Keefe
78 SC
Old 06-15-2014, 08:20 AM
Sorry can,t picture it in my head it,s been about 10 years since I worked on a torsion bar 911
1995 993 coupe
2012 Boss 302
Old 06-15-2014, 08:28 AM
patkeefe's Avatar
This is the root of my problem. CRS.
Patrick E. Keefe
78 SC
Old 06-15-2014, 08:29 AM
Above the cantilever rod.
That cable looks right
Have some one hold the pedal up to give more slack while you are fitting it on to the transmission.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-15-2014, 08:38 AM
ROW '78 911 Targa
timmy2's Avatar
I used a bungee cord to hold the clutch pedal up. Gave me the slack I needed.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-15-2014, 10:05 AM
You need about 18 to 21 turns into the Clevis in the tunnel of the cable itself.
Bruce
Old 06-15-2014, 10:11 AM
patkeefe's Avatar
Thanks. I don't have the pedal end connected yet.
Patrick E. Keefe
78 SC
Old 06-15-2014, 11:16 AM
