Help needed Flapper Box
Hello guys, can you please tell me how to disconnect the flapers boxes lever inside the cabin please, here is the pic,
Thanks!
Old 06-15-2014, 09:32 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
Are you replacing the cables or just disconnecting them? If replacing, they can be cut (though this is difficult) at the loop. If you are just disconnecting, untwist the loop using needle-nose pliers, then manipulate the levers so you can get the cables out (they don't bend very well).
The heater handles pull straight off the lever, which might give you more flexibility in maneuvering the pieces.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 06-16-2014, 08:49 AM
