How smooth does your MFI engine run?
How smooth does your MFI engine run.
My engine pulls strong etc. It has maybe 10,000 miles on a professional rebuild, never fails to start, never dies, but at idle it will miss every couple of seconds. It has optical ignition and is timed properly etc, but as this is the only 911 and only MFI car I've ever had, I don't know what normal is. Or maybe I do and this is it - which is what I suspect. Am I expecting too much that it never miss - what with it being 42 years old and is mechanically injected to boot???
A very nebulous/non-scientific question I know - but I'm curious for your seat-of-the-pants experience. Thanks
1972 911T/S MFI Survivor
Old 06-15-2014, 06:04 PM
Banned but not out, yet..
RSBob's Avatar
Owned a MFI for 12 years and it always ran like a clock. Never missed, surged or otherwise misbehaved. What is happening is not normal. Don't have the experience to diagnose though. Good luck finding a solution and enjoying a well running. MFI car
Old 06-15-2014, 07:28 PM
Mfi
Hi Daepp.
My 73 T, MFI Is very smooth, powerful, fun to drive. No missing or popping. During the restoration, I had the MFI pump rebuilt to E spec by Gus @ Pacific Injection. I had Matt Blast in Boston rebuild my T throttle bodies to E spec. I found a set of E stacks here on Pelican. It's been rock solid.
1973 911 T MFI Coupe, Aubergine
Old 06-15-2014, 07:37 PM
cnielsen's Avatar
Mine runs butter smooth. Sounds like faulty fuel injector. Did you check or replace yours?
Old 06-15-2014, 08:04 PM
Are you running a stock Bosch CDI box?
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-15-2014, 08:14 PM
Send a message via Skype™ to Porboynz
What everyone says above, mine will idle <400 RPM and you can just about hear every cylinder fire, 42 years old and never been touched. Amazing.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 06-15-2014, 09:32 PM
tobluforu's Avatar
If your butterflies are org. then it's going to pop/fart once in a while. Also, if you have a franken motor where one has different cams, cylinders, etc then it's tough to get just right.
Old 06-16-2014, 03:58 AM
What is a "fraken motor" never heard that term!
03 Boxster
Old 06-16-2014, 07:21 AM
65rsr's Avatar
'franken' motor, as in Frankenstein.
This Franken Motor starts like a street car, purrs like a kitten at idle, and screams like a demon when it come on cam.
"lightning illuminated the object and discovered its shape plainly to me; its gigantic stature, and the deformity of its aspect, more hideous than belongs to humanity, instantly informed me that it was the wretch, the filthy demon to whom I had given life."
Old 06-16-2014, 08:32 AM
that 'splains it.........I just did not know what "Fraken" might be.
03 Boxster
Old 06-16-2014, 10:12 AM
IS THIS A "Fraken" motor?
this might be a Fraken motor.
It has an overhead fanshaft!!
03 Boxster
Old 06-16-2014, 10:16 AM
tobluforu's Avatar
My car is not like the ones above, but if you take solex cams, rs pistons, T stacks and heads, E pump, mate it to a 75 tranny with an exhaust you built yourself, you my friend have what is termed a franken-motor.
Old 06-16-2014, 11:17 AM
tharbert's Avatar
Maybe you're referring to "Franken" as in Frankenstein rather than "fraken? Autocorrect isn't going to help with this one.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 06-16-2014, 11:22 AM
tobluforu's Avatar
Whooops, you are correct my friend, corrections have been made, reading glasses used.
Old 06-16-2014, 11:36 AM
Bandwidth AbUser
Jim Richards's Avatar
Originally Posted by regency View Post
Hi Daepp.
Love your car, Steve!
My old aubergine 73E w/ 2.7 RS-spec engine was smooth at idle, as well. My throttle bodies, stack and linkage were all rebuild to S/RS specs by Matt Blast. I ran a Pertronix ignitor with an MSD box. My dizzy was new, too.
Jim R.
Old 06-16-2014, 11:39 AM
Thanks for the input.
The car has the numbers matching case, original T MFI and original TB's - not rebuilt. Pump has never been into. It case DC60 cams, JE 9.0 pistons and used S cylinders. It was professionally put together by Supertec. And AFAIK the injectors are original and "unrestored" or simply removed and re installed.
It has always run strong, rich, and misses every once in a while, but not all the time like a bad wire/plug. It has plenty of power.
Henry offered to rebuild the entire MFI but I was running out of $$. Since the optical ignition was installed it has been so trouble free that I have just lived with it, but it has always had this "miss". When it's happening, it might miss once every 15 seconds. Perhaps it IS an injector - can they be serviced? And what tells them to open?
Old 06-16-2014, 11:50 AM
tobluforu's Avatar
Is it miss, or is it a mini back fire through one of the stacks, kind of sounds like it spits?
Old 06-16-2014, 01:02 PM
Under the radar
Trackrash's Avatar
If only I could get my Webers to run that good...
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-16-2014, 01:43 PM
On decel in say second gear I'll get an occasional pop that I always believed was from worn TB's, but this is a miss at idle - like at a stop light. They are not rhythmic - just every so often, 3 or 4 times a minute.
Old 06-16-2014, 01:56 PM
tobluforu's Avatar
How old are your plug wires? Mine did this just tad, decreased timing and this fixed it.
Old 06-16-2014, 04:28 PM
