Removing factory stickers from dash crash rail
I picked up a nice dash crash rail (knee guard etc) that has the factory sticker on it for cruise control operation. My '74 doesn't have cruise control and the joke had worn off so time for the sticker to go away. Any one have a recommendation on best way to do that without harming the pad?
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 06-22-2014, 08:11 AM
non-whiner
mreid's Avatar
WD40. Let it soak in and you can remove both the sticker and the adhesive.
"Too much is just enough."
Old 06-22-2014, 08:16 AM
Taking it apart is easy
Jerome74911S's Avatar
I don't know what it is stuck on with, but have you tried a hair dryer, or a heat gun on low temp? It's hard to imagine softening adhesive by other means, if it is indeed stuck on. What color is the knee pad? Will there be a non-faded spot under the sticker?
In the end, maybe you need an appropriate sticker to go over the old inappropriate one.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 06-22-2014, 08:18 AM
RETIRED
Joe Bob's Avatar
Low temp het gun and then peel, goof off for the residual glue.
2012 ML350 3.0 Turbo Diesel
Old 06-22-2014, 09:39 AM
Cooper911SC's Avatar
Those are just an adhesive backed sticker. I recently installed a new Cruise sticker on a client's 911SC. The original had been peeled off and stuck haphazardly to the shift console.
Cooper
Old 06-22-2014, 09:48 AM
m110's Avatar
yes
1988 Carrera Coupe
Old 06-22-2014, 05:05 PM
Been here a while
Just got mine off with finger nail.
Old 06-22-2014, 05:11 PM
Senior Advisor
James Brown's Avatar
put one of them "ass, grass, or gas" stickers over it LOL
08 Cayenne Turbo
Old 06-22-2014, 05:30 PM
Thanks guys - this one was low miles and stored inside so fingers crossed.
Won't something like WD40 mark the rest of the vinyl?
911 w/ 3.2
Old 06-22-2014, 06:08 PM
Regis turd ab user
WD40 is safe, I wouldn't use Goof Off, too hot and could pull the dye and melt the vinyl.
Try some heat, even steam from an iron followed by adhesive remover, 3M is great and safe. Turtle Wax bug and tar remover works great on a lot of things and is safe and cheap.
Old 06-22-2014, 07:34 PM
