Northern Motorhead
wildcat077's Avatar
Anybody weld in some RSR strut bar mounts ?
Hey guys,
I plan on welding in some RSR strut bar brackets that i just received from TRE and it seems there is not much clearance on the driver's side between the shock tower and where the neck from the fuel tank and the junction hose from the filler neck are ...
I kind of figured i would have to remove the tank to weld in the driver's side bracket but did anybody do this themselves and do you have any tips before i get into this project ?
Thank you !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 01-20-2012, 09:23 AM
Hi
After you called this a.m., one of our clients wanted one installed, with a stock gas tank.
If you push the gas tank filler neck slightly inwards, it all fits without mods to the bracket. We moved the bracket back a little from standard install location- see these pics
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 01-20-2012, 04:25 PM
Northern Motorhead
wildcat077's Avatar
Thank you Dave,
You're the best !
I sure wasn`t expecting such a quick solution ...
Guess when you deal with professionals,you get professional service
Cheers !
Phil
Cheers
Phil
Old 01-20-2012, 04:40 PM
Bird. It's the word...
Fishcop's Avatar
Oh oh, I welded mine in without reference to the tank...
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 01-20-2012, 06:11 PM
Max Sluiter
Flieger's Avatar
Mine is center-fill.
Old 01-20-2012, 06:14 PM
advtracing's Avatar
Did you weld in the rsr braces with the tank in?
"Funding my obsession one nut at a time"
Old 01-20-2012, 06:51 PM
Northern Motorhead
wildcat077's Avatar
No, the tank is coming out before i weld up the brackets !
I certainly don't want to blow up my car and the garage which is part of my house ... lol
Cheers !
Phil
Cheers
Phil
Old 01-20-2012, 07:13 PM
safe's Avatar
Does the RSR type strut bar have a better function than the bolt on type?
I'm fitting coilovers to my car and are considering what kind of modifications I need to do in the front.
Magnus
Old 01-21-2012, 02:16 AM
Northern Motorhead
wildcat077's Avatar
I'm doing it because i had the Weltmeister strut bar with the cheap mounting brackets that i had to reweld twice ...
It also frees up your strut mounting bolts as your strut bar is no longer attached to the strut plate.In my case i'm installing some Tarret camber plates and i wanted the cleaner look in the trunk area.
You can PM Dave at TRE,he's very helpful and should be able to answer your question !
Cheers !
Phil
Cheers
Phil
Old 01-21-2012, 06:36 AM
Tired Member
DaddyGlenn's Avatar
I think you'll be okay. In a wost case scenario, you could trim the tank neck and use a longer rubber hose that would have some give.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 01-21-2012, 06:57 AM
Fishcop's Avatar
Good point. Must remember to use the hack saw and not a cut-off wheel
John Forcier
Old 01-21-2012, 10:57 PM
300hp 1800lbs is the goal
pksystems's Avatar
subbed.... I noticed this issue after I made/welded in my brackets... I guess I'll have to notch the left bracket
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 01-22-2012, 05:17 AM
To do this on my 1984 Carrera, we had to move the fuel lines and remount the fuse box about 4 inches towards the nose. Here's a shot of the finished product:
Old 06-21-2014, 02:02 PM
