cabriobrad's Avatar
1968 fuse panel assignment
Anyone one know starting from 1 being the bottom wire in the photo, to 12 being the final wire at the top on my 1968 911L, what are the fuse values for the entire block?
I have looked too, but I find unless you word it absolutely correct, you come up with zero results.
Brad
1968 911L #11810584
We first met in '92...now I own you!
Old 10-10-2010, 06:40 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
[QUOTE=cabriobrad;5607359]Anyone one know starting from 1 being the bottom wire in the photo, to 12 being the final wire at the top on my 1968 911L, what are the fuse values for the entire block?
Brad
Brad,
Try this.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-10-2010, 10:34 AM
cabriobrad's Avatar
unfortunately doesn't cover my year
1968 911L #11810584
Old 10-10-2010, 11:02 AM
1966 - 912 - SOLD
lane912's Avatar
i was too tired to be pretty last night!
Old 10-10-2010, 11:37 AM
68Sporto
MrJTP's Avatar
Assuming the ones in my 68 911 haven't moved around in the last few decades the values are as follows:
1 8 amp
2 15/8 amp
3 25 amp
4 25 amp
5 8 amp
6 8 amp
7 8 amp
8 8 amp
9 8 amp
10 8 amp
11 8 amp
12 8 amp
I'm a bit curious about fuse #2. I assume (again) that the 15 is peak current and the 8 is nominal current.
I got the numbers from the back side of each fuse in my fuse block. I would guess they are also in the owners manual but the PO still has the one for my car.
Tony
Porsche owner since 1967
1998 Boxster
1968 911 Sportomatic project
Old 10-10-2010, 12:23 PM
How about this?
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1965.jpg
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-10-2010, 02:34 PM
This link may help, of just confuse even more.
912 Board - Viewing Topic: Need help with fuse locations...
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 10-10-2010, 02:48 PM
fuses
Here is a pic of the factory fuse designation from my '68 911L
Sorry, It looks like there are no values shown for the fuses.
Matt Cooley
1974 911
Old 10-10-2010, 05:59 PM
cabriobrad's Avatar
I have that too, unfortunately I am in the same boat...however I did notice that your 68 looks to have been built about 572 cars before mine...wow...small world eh!!!(sorry...from Canada)
1968 911L #11810584
Old 10-10-2010, 06:34 PM
Grady Clay's Avatar
From an earlier post of mine....
Here is the early (SWB) fuse block.
The early fuse block (’65-’68) is prone to corrosion failures as
others. The formed “rivet” connections are long-term subject
to corrosion. This occurs in two different places. First is the
spring fuse connection is crimped under the wire terminal and
corrosion occurs there. Second, there are three back-side
connections between fuses on the source side that can corrode
to the wire terminals. If there is any corrosion, resistance
results and the connection gets hot. Typically this damages
the phenolic base and releases the “rivet” connection. This
becomes progressive until the connection is lost – usually
ruining the entire assembly.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-11-2010, 05:46 AM
304065's Avatar
According to the Factory owners manual p. 66
"All fuses are 8/15 amps except
Fuse 4 (wipers, screen washers) - 25/40 amps
Fuse 3 (auxiliary heater) - 25/40 amps
On the same page the lamp values for reference:
Headlamps 45/40W
Foglamps 35W
Back-up lights 25W
Stop lights 18/5W
Blink lights 18W
Interior lights 10W
Trunk light 5W
Parking lights 4W
License plate lights 4W
Instrument light 2W
Control light 2W
Hope this helps
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-11-2010, 05:55 AM
1 8 amp
2 15/8 amp
3 25 amp
4 25 amp
5 8 amp
6 8 amp
7 8 amp
8 8 amp
9 8 amp
10 8 amp
11 8 amp
12 8 amp
Has anyone notice the factory wiring diagram and the repair manual have the fuse box in backwards? 12 to the front and 1 to the rear.
Regarding the two different fuse ratings for number 2, I believe it is because the cigarette lighter was an option so it would need a bigger amp fuse. 8 without, 15 (16) with.
Old 06-25-2014, 09:29 PM
304065's Avatar
Yes, if you look at the photo I took at the top of the thread, the numbers on the fuse block are backwards. To get it to match the diagram, it had to be reversed!
Warren used to say that the task of doing the wiring diagram was assigned to the most junior engineers!
'81 R65
Old 06-26-2014, 04:44 AM
Updated link for post #7, good discussion and photos for fuses and the backward numbering system from owners manual and service books.
Jung
'68 912 Coupe
'82 SC sunroof
Old 06-26-2014, 07:00 AM
Tags
901/05 electrical
