maresdesign's Avatar
Help! Replaced oil cooler seals now leaking
Over the winter I pulled the motor to do a clutch job and all new external seals. The "triangle" seals, main seal, flywheel seal, etc. where replaced. Yesterday I finally got the motor back in. I added 8 quarts of oil and started it up. Everything sounded good so I backed it down the driveway. Then I smelled the burning oil and drove it back into the garage, looked under and oil was streaming out from under the oil cooler area.
Could I have pinched a seal? Any other ideas of what to look for.
I'm a bit frustrated since I took my time over the winter and double-checked all procedures and torque specs.
Any help would be greatly appreciated.
Old 05-05-2014, 07:23 AM
As far as I know, you can pull the engine oil cooler without dropping the engine, so at least you will not be inconvenienced too much. Before you do anything, you should clean the area around the leak so you could definitely identify the leak. Then, I would drain the engine oil into a clean pan so you could re-use. When you remove the oil cooler, you'll be able to see if you pinched the seals. I did mine a few years back, and it was pretty straightforward to replace the seals as they only fit one way. Are you sure it is not the oil hose that is leaking?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 05-05-2014, 08:31 AM
I checked all the hoses and they where dry. I fired it up again to watch the leak and I could see oil dripping (fast drip almost pouring) right from the bottom of the cooler. I know there could be other possible areas it is coming from though. I visually checked the Triangle and that area looks dry. It appears to only leak while the motor is running.
Old 05-05-2014, 08:46 AM
Could I have added too much oil? The motor and tank were dry and I added 8 quarts to the tank, then turned the motor over for a while before starting it.
Old 05-05-2014, 12:44 PM
OCPO
Storage Man's Avatar
I have empathy for you.
This is why I don't do plumbing in my house..
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
2006 530xi BillyBoat/H&R's....gone
Old 05-05-2014, 12:49 PM
1980SCMan
Alan Lindquist's Avatar
I'm not excited about re-using oil after it's been drained. Too many opportunities to gather some grit. However... I did it once.
I have a drain pan (with spout) that holds probably 15 quarts. I lined it with a trash can liner and drained (cold oil) into the bag and then closed the top of the bag. By pulling part of the bag through the drain spout, I was able to fill recently emptied oil quarts with a funnel and later re-introduce the oil.
I was fighting the same thing as you - significant leak after the triangle of death. In my case, the big oil hose had given up after being "handled" for the engine-out-and-back-in part of that job and I had to drain $75 worth of Valvoline VR1 20-50 that had just several hours of run time.
New hose and clamps, nearly new oil. Done. But still don't like the idea of doing that and I don't think I'd do it again.
Old 05-05-2014, 01:12 PM
Banned
My bet is that you either didn't get one of the oil cooler seals to situate properly or the oil cooler was damaged during the removal/install. Since you have to remove it again anyway, it would be a good idea to take it someplace to have it pressure tested (if you can't do that at home).
Old 05-05-2014, 01:30 PM
I changed the seals when the motor was out of the car and was careful handing the cooler. I just realized that I never soaked the seals in oil as I think I was supposed to do when installing the new ones.
Looks like I've got some more wrenching to do.
Old 05-05-2014, 01:33 PM
Banned
No need to soak the seals in oil - can smear some silicone grease on them - works much better and is way less messy. One quality brand is Danco 484-846-7500 - in the plumbing sections of hardware stores.
Old 05-05-2014, 01:35 PM
Photo below shows the new seals I installed. I did, however, remove the seals to wipe off the Silicone RTV as I read that it could clog oil passages if a piece broke off.
Now I wonder if a seal did slip out of location when I bolted it up.
Old 05-05-2014, 01:55 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
You aren't the first guy to replace the seals (properly) and have leaks. Although your picture shows the seals certainly seem to stand proud enough, maybe they are not as thick as what came out. Don't suppose you have the old ones so you can compare the dimensions. I know one of our local guys (JJ911SC) also had a problem after he changed the seals, you can search for his thread and what he did. Good thing your drive was short, could have been a much worse outcome.
Old 05-05-2014, 03:05 PM
I didn't save the old ones. I do remember they were hard as a rock compared to the new ones. Thanks for the info.
Old 05-05-2014, 03:20 PM
ROW '78 911 Targa
timmy2's Avatar
Don't use RTV on any part of the engine. That is not the same as a silicone base grease.
Dow 111 silicone grease is what most use on these to hold in place when assembling. Works great on the lower oil tube o-rings too.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-05-2014, 03:37 PM
Second the Dow 111 silicone grease.....
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 05-05-2014, 03:45 PM
howard freeman's Avatar
Third on the Dow & install the seals in the case,not on the cooler.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 05-05-2014, 03:57 PM
Fleabit peanut monkey
Bob Kontak's Avatar
+1
I bet something happened that stressed and cracked the cooler vs cooler seals.
1981 911SC Targa
Old 05-05-2014, 04:18 PM
The use of RTV is a SURE way to induce leaks. Porsche (and other manufacturers) design the interface to be seal to metal. Their engineering departments are way bigger than yours, and I'd probably go with what they did, given a choice. There are places where sealants are preferred or required, and even then you should use the particular sealant for which the joint was designed.
The Cap'n
Old 05-05-2014, 04:34 PM
I crushed the idiot light switch washer too tight and distorted the copper to cause an oil leak when running. Oil ran right too the bottom forward nut on the cooler.
The cooler isnt suposed to be flowing until the thermostat opens at 180 degrees.
Bruce
Old 05-05-2014, 04:52 PM
Northern Motorhead
wildcat077's Avatar
You got the newer updated green seals ... probably just had one misaligned when you reinstalled your cooler.I was kind of weary myself when i replaced mine a few years back !
I remember installing mine with a small dab of Lucas oil treatment just to keep them seated in place ... that stuff is almost thick like molasses ...
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-05-2014, 05:16 PM
Bruce
Great deductive thinking Flat6pac! Yes, if the OP had indeed just started a cold engine and backed it out the driveway, there should be NO oil flowing thru the cooler. Like you said, 180 deg to open the thermostat takes a good bit of time, till then the thermo is slap shut!
Also, the lower single seal is just oil under almost no pressure (gravity flow), so probably not that.
Me thinks it's time to look elsewhere. Oil leak flows can be very misleading.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-05-2014, 05:24 PM
