sugarwood's Avatar
Requesting explicit detail on how to replace fuel filter ?
I'll apologize in advance!
Unfortunately, the esteemed "101 Projects" book simply says "Remove filter. Replace filter. Done!".
As a mechanically challenged poster, I need a little more guidance than that.
None of the bolts on the replacement filter spin, so I'm not clear to me what moves and what's fixed.
Do you spin the filter?
Can someone spell out how you're supposed to remove it?
For example, "Put a wrench on nut #1, spin filter clockwise"
or "Spin nut #2 counterclockwise while holding nut #1 with a wrench" etc
1986 Bosch Icon Wipers coupe.
Old 07-06-2014, 05:35 PM
There is a little more detail in the on-line tech article:
Pelican Technical Article: Fuel Filter and Accumulator Replacement - 911 (1965-89) - 930 Turbo (1975-89)
EDIT for correction: You do want the upper most and bottom most nuts to move (but do not twist/torque the fuel lines).
You may have to brace/block these outer most nuts with a locking wrench or vice grip, which must have leverage on something adjacent to it to prevent them from torquing the lines. Or you can grow a third arm, or have a buddy help you.
I found the fuel filter and accumulator sort of unnerving to work with, it's high pressure fuel you are dealing with.
Old 07-06-2014, 05:54 PM
otto_kretschmer's Avatar
you need two wrenches
I don't remember the sizes off the top o my head, maybe a 14mm and 17mm
you should have all the sizes at least between 10mm and 19mm
righty tighty
lefty loosy
Old 07-06-2014, 06:13 PM
ROW '78 911 Targa
timmy2's Avatar
Hold nuts 2 and 3 in place. Loosen nuts 1 and 4.
Top first, then the bottom.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-06-2014, 06:21 PM
sugarwood's Avatar
You do not want the upper most and bottom most nuts to move (can twist/torque the fuel lines).
You may have to brace/block these outer most nuts with a locking wrench or vice grip, which must have leverage on something adjacent to it to prevent them from spinning. Or you can grow a third arm, or have a buddy help you.
Are these 2 posts directly contradicting each other?
As I understand,
kach22i is saying NOT to spin the outside nuts b/c they will twist the hard fuel lines (So, are you saying to turn nuts #2 and #3?)
Meanwhile, timmy2 is saying to spin the outside nuts. (Spin nuts #1 and #4)
Anyone know which one is correct?
Are nuts #1 and #4 rotatable?
Or are they a fixed part of the fuel line and the filter needs to screw into them?
Old 07-06-2014, 06:27 PM
pete3799's Avatar
Hold nut #2 from turning
loosen nut #1
Hold nut #3 from turning
loosen nut #4
Pete
79 911SC RoW
Old 07-06-2014, 06:32 PM
Chain fence eating turbo
Hold inner nuts stationary while outer ones get loosened. Do this for each end. Order of ends doesn't matter IMO.
Old 07-06-2014, 06:33 PM
I replaced mine last year; procedure was exactly as timmy2 says.
Old 07-06-2014, 06:34 PM
sugarwood's Avatar
Thanks for clearing that up!
Consensus says that the outer nuts #1 and #4 are the ones to run.
They must spin in place, while the filter stays fixed.
I wonder what kach22i was trying to say ??
Old 07-06-2014, 06:38 PM
Maybe, I just remember that you don't want to twist your fuel lines.
Like others said, two wrenches, righty tighty, lefty loosey.
The bracing I remember had to do with the torque being transmitted though the filter housing despite the two wrench method.
timmy2/pete3799 are right, but watch what's happening at the top and bottom while you are doing it.
This video helped me when I replaced my fuel filter.
http://m.youtube.com/watch?v=sf4-NAvB_lc
aualexa2's Avatar
Go to YouTube and search yellowcapgarage and fuel filter.
Edit: jonvi, you beat me by a minute
Alex
‘73 914 1.7 Phoenix Red
'99 SPB #79
'16 Cayman GT4 GT silver
Gone: '87 911 Blk/blk sunroof coupe, '13 991S Dbm/ag non-sunroof coupe
Old 07-06-2014, 06:39 PM
kuba_kuba's Avatar
Takes some force, especially the lower ones...
'88 911 Targa
Old 07-06-2014, 06:49 PM
I think when I did this awhile ago, I found it easier to remove the curved pipe on the top with the filer (there's another connection that's blocked in the photo) and then remove the top fitting outside of the car.
If this doesn't make sense, then just do what pete3799 says.
Oh, and don't forget to disconnect the (-) battery cable. When you remove the filter you'll have gas leak out, and you don't want any sparks.
Good luck!
Old 07-06-2014, 06:52 PM
Good video.
If your right arm is stronger than the left arm, and the right arm is doing the turning, add in some sticking from corrosion and that's where some twisting is possible.
That's what I remember, and that's my warning.
sugarwood's Avatar
The video is exactly what I needed.
Brilliant level of detail.
Thanks everyone!
Old 07-06-2014, 06:55 PM
ROW '78 911 Targa
timmy2's Avatar
Spray a little Kroil on that top nut and let it soak in for a while before trying to undo it, it looks a little corroded.
Dennis
Old 07-06-2014, 06:57 PM
Residual fuel pressure..........
kachi,
That's is true if you just ran the fuel pump a few minutes ago. The residual fuel pressure would drop to almost zero on the gauge after 8 hours. So if you leave the the engine over-night, the following the day there will be no more residual pressure to worry. But there still be fuel in the lines but not under pressure to be of concern.
Tony
Old 07-06-2014, 07:39 PM
Dr J's Avatar
It helps to put the wrenches clocked about 30 degrees so that you can squeeze them to loosen and the same idea to tighten them up since it gets tight in there.
Old 07-07-2014, 04:39 AM
lonewolf's Avatar
Originally Posted by dr j View Post
it helps to put the wrenches clocked about 30 degrees so that you can squeeze them to loosen and the same idea to tighten them up since it gets tight in there.
+1
Old 07-07-2014, 06:13 AM
