Replace headstuds or reuse original ones??
My car is in the shop undergoing a topend only rebuild at the moment. 158k on original 3.2 Carrera motor. Street car with occasional track days for fun. Will continue as a stock daily driver (no serious track time).
Talked with service tech and we discussed the headstuds. They are all original and none are broken. Minor corrosion on a couple of the intake ones but nothing too alarming. Trying to keep the overall costs in check. Service tech was on the fence on replacing and leaving it up to me. So… Would you replace or not?
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
Admittedly I'm scarred from having just done this myself on my 3.2, but I would replace them without hesitation!
Assuming they are original and not previously upgraded already, they are practically guaranteed to fail at some point (at least by Murphy's Law) and it is much more expensive to come back into the engine this far at a later date.
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes. 1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights. |
OCPO
You eventually need to replace the others as well.
2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone |
Having gone through this with a 3.0 or my 914 (3 broken) I would replace them. Think of the time effort and $$ if your not doing the work yourself to replace the studs if they snap in a year or so.
If its apart, change them!
The supertec studs are good value.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Fleabit peanut monkey
Aren't the all-thread studs from later (90's) 911's acceptable for a street car? Far less money, not real exotic but hefty enough that they don't break.
This is a street car. Supertec, Raceware and the other big name brand (plus others, probably) are wonderful. But I am thinking the fatties are a good fit for purpose.
1981 911SC Targa |
replace the lower dilivar studs with steel. really no need to replace the steel top row.
abides.
If you look around, you can find a set of ARPs for $550, which is only marginally more than a set of regular steel studs, nuts and washers.
Graham 1984 Carrera Targa |
Mind you, my base of info is from old posts. Maybe it read something like steel studs "similar to the 993". Anyhoo, yes the 993 studs are expensive. They are by no means less expensive.
1981 911SC Targa Last edited by Bob Kontak; 07-07-2014 at 12:44 PM.. |
ROW '78 911 Targa
Worked for me 3 years ago. Still running strong. Reused the washers and nuts as well. Sent from my iPhone using Tapatalk
Pelican's parts catalog says steel head studs are $14.50 ea. You need 12 for the lower row to match the existing 12 on the upper row. That's $174 according to my calculator (free shipping it says too). FWIW, I haven't heard (anecdotal) of many failure reports of non-Dilavar head studs. Apply the difference toward stronger con rod bolts/nuts and other upgrades.
As for the more exotic steel alloys available (ARP, Raceware, etc.), YMMV. Sherwood |
abides.
Were the lower studs different from the uppers on 3.2s? When I pulled my '84 engine apart, all 24 appeared to be the same type of stud.
So I did more reading and it seems the general consensus is to replace the lower dilivar studs with steel and leave the uppers alone.
Does this make sense? Do the upper steel studs ever have issues?
Just do what John says. We are lucky to have his expert advice.
Just to back up what John said, I talked to a race engine machine shop in California he is one of the most respected guy's in the business he say's to use steel unless you intend to have a high performance engine and the spec's are almost as strong as the aftermarket stuff anyway.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
a magnet will tell you.
I replaced all lower studs when I found 7 broken ones in my 84 with Canyon steel from Pelican.
Part # 10-0115-101-M105. They are $14.50 now, I think $11 when I ordered them a few months ago.
Tru6 Restoration & Design |
