				Should I use NYLOC nuts on the CIS Runners?
			Should I use Nyloc nuts on the CIS runners to heads?  They weren't on there, and I really don't want to use them because it is going to be a PITA to get them going in the tight area I am working.  Wayne uses them on his rebuild in the book - but I was just going with new regular nuts and Wurth wave washers as the way it was when I took it apart.  What do you guys think?
			 ROW '78 911 Targa
			I've used both. I used a smaller OD nylock 12mm.
			 non-whiner
			I did and they work well.
	"Too much is just enough."  |
