Various questions
Hi all, I've just had to re register as i haven't used this forum in a long while and my old email is invalid, so please don't think that I'm butting in on things. I'm close to finishing a 1970 911 e total rebuild and have just a few questions to ask the very wise people out there. Q1, on the throttle bodies I have noticed that there are small circular black plastic spring retainers on the throttle shafts ( 1972 911 t bodies ) that help the springs hold their position, where can I get a set of these as mine are broken. Q2, my Bosch distributor has a thin Bakolite shim at the base of the shaft internally below the counterweights, this is in pieces, where could I get one or will it work without it. Q3, I have just purchased a new set of SSI heat exchangers but for a 1972 onwards, the left hand exchanger has a heat box covering the lower pipes which I'm sure I don't need. Should I cut this's out ???? Any help would be much appreciated. Thanks.
Old 08-09-2014, 04:22 AM
ROW '78 911 Targa
timmy2's Avatar
I can't help with the MFI questions but I have had the experience of having to sign up new after being off the forum for 5 years or so.
Just my way of bumping your questions back to the top.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-09-2014, 11:51 AM
Thanks for that, i cant believe that no one can help me out at the moment, maybe the usual Sunday morning crew will be able to help..
Old 08-10-2014, 01:58 AM
ROW '78 911 Targa
timmy2's Avatar
Various questions
Actually I can answer one or two questions.
partsKlassic dot com should have the parts you need for your distributor. They had a shim kit for my '78 and seem to specialize in early year distributors.
If you want heat from your heat exchangers don't cut anything off. Maybe post a picture of what you are referring to on the SSI's.
Dennis
Old 08-10-2014, 03:04 AM
hi, just sent parts Klassic an email about the dizzy part, Thanks. If anybody is wondering what piece of the SSI heat exchanger that im on about ive uploaded a photo to help.
Old 08-10-2014, 04:30 AM
The tinware here is ( i believe ) is not needed for my 1970 2.2e , but comes as standard on 2.4 onwards, so was thinking of cutting this off.
Old 08-10-2014, 04:33 AM
Bump, Anybody please.
Old 08-10-2014, 08:43 AM
ROW '78 911 Targa
timmy2's Avatar
Thanks for the picture, it helps a lot.
I believe the tinware in question is used to direct warm air to the warm up system for the MFI air intake system.
Dennis
Old 08-10-2014, 09:00 AM
