| Registered Join Date: Feb 2014
				Carrera 3.2 Factory brake pads
			Hello all,  I am gathering parts in advance for replacing both front and rear brake pads. I would prefer to keep the original clip-on pad sensors and use factory/Porsche OEM pads if possible. The rear set for the wide M caliper is still available from Porsche with correct notches in the backing plate (#911.351.923.00), however the front set (listed as 911.351.950.06 with box labelled 911.351.950.06 and pad printed with 911.351.940.05) requires the newer glue-in sensor (as pictured). Does Porsche currently manufacture a front brake pad set for 1988 Carrera with original notched backing plates? If not, is there an NOS part number or Textar/Jurid pad set I should be searching for? Thanks for your time and input!   | ||
|  07-19-2014, 02:16 PM |
| Registered Join Date: Nov 2001 Location: Santa Maria, CA
			Porsche doesn't manufacture much of anything, except for completed cars.  The pads are outsourced.  You should be able to find what you need on the aftermarket.  As always, if you give us a bit more information about the specific application, you'll be able to get a better answer. The Cap'n | ||
|  07-19-2014, 02:28 PM |
			Thanks! Car is an original 1988 911 3.2 cabriolet, street-driven only, no modifications from stock.  It arrived with a new set of Bendix pads (which fit the original sensors), I was simply trying to upgrade (?) to the original factory pads for perhaps better braking. | ||
|  07-19-2014, 02:35 PM |
| Registered Join Date: Apr 2008 Location: Norcross, GA
			Mintex makes them with the notches. They work well and are inexpensive and quiet.
				__________________ John '86 911 Coupe | ||
|  07-20-2014, 07:01 AM |
| Registered Join Date: Jun 2009 Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
				 |  ^^^^^ Here's what I use on our '86. Good luck, Gerry
				__________________ 1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." | ||
|  07-20-2014, 08:28 AM |
			Just wanted to post my findings for future users: As of this time, there are no available factory (Porsche) or Textar front brake pads available with notches to fit the original "clip" sensors on the 3.2 series; all current factory and Textar pads (including the part number Gerry thoughtfully provided above) have been superseded to the "press-in" type sensor that resides in the pad material. I was told that this was a fairly specific brake pad that was manufactured for cars built some time ago, and presumably this allows for consolidation of manufacturing. As noted above, the Mintex front pads are still available in the notched version for the original sensors, and Porsche still retails the rear pads with notches. | ||
|  07-22-2014, 02:42 AM |
| Registered Join Date: Jan 2006 Location: Clayton NC
			Some people  just take the sensors and tie them up out of the way and install whatever pad they desire that fits.
				__________________ gary 70T coupe forever almost done 88 Carrera Targa diamond blue | ||
|  07-22-2014, 02:50 AM |
