1986 911 targa
jeffs targa's Avatar
reference sensor connector
Help, The connector to my reference sensor is missing the female end plug all the is now is small staycon type which one is broken any ides to replace /repair it?
I am trying to upload photo if can help .
Good news i found to no start problem
Old 08-28-2014, 02:12 PM
1986 911 targa
Here is photo hope this is ok
Old 08-28-2014, 02:20 PM
steely's Avatar
Confirm this first.
Junior timer connector from Eagleday.
AMP Connectors/Terminals
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-28-2014, 03:26 PM
Brew Master
cabmandone's Avatar
Maybe try the used parts forum to see if someone will part with one from an old harness??
Old 08-28-2014, 05:58 PM
1986 911 targa
Thanks, steely looks like they just fit the bill there is a electronic supply house here in Albany that also may have something that will fit guess its worth to give them a shot.
As you can see the female side is gone.I have had the car for a year now still much to learn.
Old 08-29-2014, 03:02 AM
connector
I have one and notes because I had a problem with the female side collapsing inside the connector. My notes are only from the day I did the job and the replacement piece is not proper color code but notes have the correct color code for the particular part I was replacing.
There is a 50/50 chance its what you need.
I PM ed my phone number to you
Bruce
Old 08-29-2014, 01:55 PM
