| Registered Join Date: Jun 2003 Location: Fresno, CA
				Any Advice on How to Remove the Throw Out Bearing?
			I need to change out the throw out bearing - This is for a '74 911 915 Trans. It looks like there is a circlip in there but hard to tell as there are no tiny holes for a tool to grab. I'm sure I'll figure it out but thought I'd ask while I'm at work, maybe I'll know by the time I get home. Thanks! | ||
|  07-25-2014, 01:16 PM |
| Registered Join Date: May 2008
				 | Quote:
  ...  Don't ding yourself! EDIT; Put a wood block, a little bigger than the TOB, on your bench, set the TOB against the block, and push down on the pressure plate a little...
				__________________ Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 07-25-2014 at 01:23 PM.. | ||
|  07-25-2014, 01:21 PM |
| non-whiner Join Date: Aug 2012 Location: Slightly right of center
			You really need a press to do this right. You may damage yourself without one!
				__________________ "Too much is just enough." | ||
|  07-25-2014, 02:19 PM |
| Registered Join Date: Oct 2003 Location: London Ont Canada
I,ve done it with pressure from my knees on the floor, so have lots of guys. If you have a drill press you can bridge the TOB with a piece of 2x4 and compress it. The 2x4 leaves enough space to pry up the lock ring
				__________________ 1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 | ||
|  07-25-2014, 03:54 PM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			you push down on the PP with the sides of both hands while using a small pair of expanding pin style snap ring pliers in one hand. a press? bwaaaaa!
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 | ||
|  07-25-2014, 04:27 PM |
			Ok, just to clarify: In the photo below, the snap ring is the very thin ring that is next to the very center sleeve. You cannot see it in this photo but there is a small 1/4" gap in this ring and I need to somehow pry it out. I've already tried with snap ring pliers but that won't work. I will try again with a tiny screw driver. Next, I need to put a block of wood under the existing throw out bearing - But what side of the pressure plate faces down? Afterwards, I will use my fat a$$ to push down on the pressure plate. Once I get the spring to move - then what? How does the throw out bearing come out? I know these questions may sound stupid and maybe once I get some movement, I will understand. But, with the spring being so strong, I cannot currently get any movement and so it's had to tell which way things are supposed to move. Thanks again for more tips. I plan to do this this weekend as I just picked up my newly resurfaced flywheel. (and yes, I am going to use new bolts).   | ||
|  08-08-2014, 10:25 AM |
| Immature Member |
			Put your knees on either side of the pressure plate as you have it in the picture.  That will relieve the tension on the thrust washer and you can spread the circlip with snap ring pliers or two screwdrivers.  Maybe this will help:  It's only the tension from spring #4 in the diagram that you need to overcome.
				__________________ 1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" Last edited by dentist90; 08-08-2014 at 10:29 PM.. | ||
|  08-08-2014, 10:25 PM |
			Make sure that you see how #4 is installed and put it back the right way!!!
				__________________ Keep the Shiny Side UP! Pete Z. | ||
|  08-09-2014, 06:57 AM |
| Registered |
			^^^ What he said. I did mine at night in a frick'n semi-dark garage, trying to make it upstairs before the wife killed me. Put the motor back in the next day, pumped the clutch a few times and right to the floor it went. TO bearing popped right off. ugh!
				__________________ 72 911 Although it is done at the moment, it will never be finished. | ||
|  08-09-2014, 07:21 AM |
				 | Quote:
 I got the old throw out bearing removed and now to install the new. | ||
|  08-09-2014, 07:28 AM |
				 | Quote:
 Thanks! | ||
|  08-09-2014, 07:29 AM |
