Removing undercoating stuff?
My SC has some kind of black undercoating material around the tops of the shock towers, in the trunk. Looks like it was applied at the factory - although I can't figure out why they did that (I've also seen the same on some 914s - some had it, some didn't).
Anyways, any suggestions on the best way to remove it? |
Senior Member
I think that stuff helps waterproof your trunk. Undercoating is removed with a plastic scraper and a heat gun.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Friend of Warren
Super is correct. However that stuff gets brittle when it gets old. You might find that using the plastic scraper and a light touch from a hammer that the stuff will just chip off in good size pieces.
Kurt V No more Porsches, but a revolving number of motorcycles. |
For the stubborn tar remains ... Varsol or 3M Paint Cleaner on a terry cloth.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
