scarceller's Avatar
Here's what happens in old cars:
- Old contacts get oxidized and corrode slightly
- This corrosion results in increased resistance at the contact
- Increased resistance = heat at the contact
- Then run significant current through the contact and you quickly get thermal run away where more heat generates more resistance, and then more heat, ...
- End result, melted contact that gets so hot it melts any surrounding plastic!
Solution - clean the contacts if possible. But doing this to all contacts is just impossible. The other solution is to properly fuse circuits as already pointed out.
And the very best is install relays that limit the amount of current through the head light switch and the hi-lo beam stick switch. The relay contact can also corrode but those relays are very cheap compared to the stock switches.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-15-2014, 01:02 PM
justjones's Avatar
So could simply cleaning the headlight switch contacts restore function? Or is it once you have a melt down like I encountered you are looking at a new switch?
Thanks!
Old 08-15-2014, 01:31 PM
ROW '78 911 Targa
timmy2's Avatar
Help!! Headlight switch Failure?
The relay kit is used to remove almost all of the current that the stock headlight system runs through the main headlight switch, the turn signal hi/low switch contacts and through the lights.
The only current the switches see after installing the relays is what is required to activate the coils. (Much lower)
The lamps in the circuit are fused, but the switches aren't!
As was designed by Porsche.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-15-2014, 01:50 PM
Mine only lets the smoke out when I leave the lights on and turn the car off. The 1st position on the switch for running lights does not work right, but when I pull for headlights, they work fine, as long as I turn the lights off before I shut the car down.
Jimmy Foster
78 911 SC
Old 08-15-2014, 03:45 PM
gtrp's Avatar
Hello,
My headlight went out last night on the highway and when I pulled the switch I found one without a wire connected.
Could the wire have pulled back into my dash? I can't seem to locate it. I believe this is for the high/low beam flash.
81' 911sc - Weekend Project Car
09 GTR - Race Car
Widebody 911SC
Old 11-07-2014, 01:21 PM
gtrp's Avatar
Also I do smell a burning smell coming from the switch so I'll probably order a new one tonight....
09 GTR - Race Car
Widebody 911SC
Old 11-07-2014, 01:24 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
09 GTR - Race Car
And, please don't forget the 3A dash light fuse.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-07-2014, 02:18 PM
gtrp's Avatar
I shall, thanks for the idea!
09 GTR - Race Car
Widebody 911SC
Old 11-07-2014, 02:55 PM
sugarwood's Avatar
gtrp,
While you have your headlight switch out, can you compare the wiring configuration from my '86 against your SC's wiring?
I am wondering if they are the same.
14 Wires that go into the '86 headlight switch
Turn signal stalk harness
White/black -> 56 (White is the main wire color, black is the stripe color)
Grey/black -> 58L (inside)
Grey/red -> 58R (inside)
Red/white -> 75
Plug Prong harness
Grey/black -> 58L (outside)
Grey/red -> 58R (outside)
Grey solid -> 58 (between 56 & 30)
Grey/white -> N
White/green -> 57
Black/blue -> 58a
Electrical tape wrapped harness
Red/white -> 75
Red solid -> 30
Blue/black & Black/blue -> 58a
1986 Bosch Icon Wipers coupe.
Old 11-07-2014, 03:47 PM
