Aux air regulator
So was checking a few things out today and decided to check my air regulator It measured 17 ohms
But according to the Bentley book when it's cold it the little flap inside should be open to allow air through
But it's closed only has a small opening see pictures
I can push it back but there's resistance as in guessing there's a spring that pushes it closed
Can anyone confirm that this flap should be open when cold
Old 08-17-2014, 01:49 PM
Sorry forgot to mention this is my 81 911
Old 08-17-2014, 02:33 PM
Yes it should be open when cold. Yours looks fine as I've yet to see one open fully. Perform the freezer and oven tests to confirm aperture closes when hot. There are many threads on this topic if you search the forum. Cheers
Old 08-17-2014, 02:34 PM
ROW '78 911 Targa
timmy2's Avatar
I agree it is probably fully open in your picture. They don't open much more than that.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-17-2014, 04:50 PM
That's about how open they get at room temperature.
Old 08-17-2014, 05:43 PM
Really that looks like a minimum position type thing it's open 1/4 way if that
Old 08-17-2014, 07:12 PM
AAR (0-280-160-xxx)........
cali,
A good working AAR is open between 1/2 to 1/3 of the cross-sectional area of the passage hole at room temperature. Even if you placed the AAR in the freezer for many hours, it won't change significantly. The opening of your AAR looks good to me. However, if you are using this AAR (-206) for your SC, you got the wrong unit. This particular AAR-206 is built for '77 CIS engine.
Tony
Old 08-17-2014, 07:53 PM
Thanks tony that is weird the po must have replaced it
What is the correct number for the 81 sc
Old 08-18-2014, 03:35 AM
