Disconnected wire
By replacing my fuel injectors en injector sleaves today I noticed a disconnected wire on the passenger side of the car below the air box. Does anyone have an idea what it's for and where it should be connected to?
Old 05-25-2015, 11:10 AM
Member 911 Anonymous
DRACO A5OG's Avatar
A picture would really help. Please post it and we will give it a shot.
'85 Carrera Targa
PCA/POC
Old 05-25-2015, 11:11 AM
Brew Master
cabmandone's Avatar
Do you have backdated heat on your ride? That looks kinda like the connector that would go to the heater blower fan to me but I don't know why it would be on the right side of the car.
Old 05-25-2015, 11:46 AM
Also, depending on the year and specific model of 911, on the LEFT side is the thermotime switch (above the #2 and #3 runners) that may use that type of connector. Again, why it is on the RIGHT side ... ?
Old 05-25-2015, 12:46 PM
DRACO A5OG's Avatar
Thanks, can you zoom out so we can see it in reference to the rest of the engine?
+1 so far it looks like a heater blower motor wire connector 12V/ground. Does your blower motor work?
'85 Carrera Targa
PCA/POC
Old 05-25-2015, 01:05 PM
ROW '78 911 Targa
timmy2's Avatar
Only used on '78/'79 CIS for the thermal vacuum switch.
Still built into the harnesses from '80-'83 but not used. Tape it up as there is a constant 12 VDC to it while the ignition is on.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-25-2015, 01:07 PM
DRACO A5OG's Avatar
^^^^ There you have it :-)
'85 Carrera Targa
PCA/POC
Old 05-25-2015, 01:19 PM
The heat blower is working and uses a similar connector. Seems like it has indeed no function to my '83 SC. I'll tape it up so it can't harm.
Thanks for your help!
Old 05-25-2015, 01:36 PM
