Questions during alternator fan belt replacement
I had a loose fan belt on my '86 3.2. Only after ordering the 10x710 belt from Pelican did I read about the 9.5 vs 10 concerns. I will try the 10x710 belt and see what happens.
To remove the old belt, do I need to remove the AC belt? For now, I just tightened the existing belt. It had 2 inside and 3 outside. I moved all 5 outside and the belt is much tighter. I will order the 6th shim just to be sure. The directions say to crank the engine before final belt tightening. What can I disconnect in order to crank the engine with it actually starting up? Thanks PP! Last edited by sugarwood; 06-29-2014 at 09:25 AM.. |
I had a loose fan belt on my '86 3.2. Only after ordering the 10x710 belt from Pelican did I read about the 9.5 vs 10 issue. I will try the 10x710 belt and see what happens.
But, before I can do that, it's not clear how to remove the old belt from the bottom pulley. None of the existing write ups mention this step. I can't slip it off the bottom b/c the pulley housing is in the way. Do I need to remove the AC belt that is in front of it? -Yes you can, but you have to remove the A/C belt first. Once removed, it will slip easily. For now, I just tightened the existing belt. I only found 5 shims in my pulley. It had 2 inside and 3 outside. I moved all 5 outside and the belt is much tighter. Should I order the 6th shim? -I would, in fact, why don't you get a new set of six. The directions say to crank the engine before final belt tightening. I did this, but what can I disconnect in order to crank the engine with it actually starting up? Can someone post a photo of exactly what to disconnect? (Just saying "unplug the coil" or "unplug the CD box" will not help me unless you show me where it's located, and what it looks like) - No need to disconnect anything. Just crank enough to seat the belt. If the engine starts, no big deal. Check the tension after and tighten the bolt. I would suggest buying the Bentley book and read up on the tech info found on top of the page before you replace the belt. |
Member 911 Anonymous
All 5 outside is TOO TIGHT, you might ruin the alternator bearings or worse number 8 bearing seal on the block and cause a leak, when you get the new OEM length belt and new shim, place 3 in 3 out.
If you get the shorter belt 5 in 1 out
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Can you explain why this would actually be a problem? Let's say you only use 1 shim total. You then run out of alternator shaft thread and carve new threads when trying to make the nut tight. Could you not just remove the nut, add the 5 shims, and then tighten? With the proper shims now in place, the nut would now tighten while still on the original shaft threads, right? I'd think the nut would not be able to reach the newly created threads (once all 6 shims are restored) Am I understanding this correctly? Quote:
The belt certainly doesn't feel too tight with teh 5 shims outside. It has about 1/2" of play, just like the Pelican write up specifies. I plan to remove the AC belt and install the brand new 10x710 belt. When I do, I will start with 3 in/3 out and go from there. All this talk about destroying the bearings and bearing seals (?) ...it's hard to tell if that's internet hyperbole or a real possibility. Do people really destroy their engine block seals just from changing the fan belt? Last edited by sugarwood; 06-27-2014 at 11:04 PM.. |
For my own knowledge, I'm still curious how to disable the ignition for those times when you need to crank the engine, but don't want it to actually run. Like when checking for spark, for example.
Disconnect the DME relay underneath the driver seat. That will disable the fuel pump aka kill switch on the fly.
As far as over tightening, just think about the stress you will be putting on the two points, alternator and number 8 bearing on an almost 30 year old car. I am just saying. I may be wrong but I rather error to the safe side. Yes, 1 maybe 2 more on the outside may work but if your belt is that stretched you want to change it sooner than later. But that is what you are doing :-)
83 911 Production Cab #10
The changing of the belt is one of the project from the 101: Pelican Technical Article: Fan Belt Replacement - 911 (1965-89) - 930 Turbo (1975-89) P.S.: Your car does not have a CD box
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
However, the 101 book (and link) made no mention of removing the AC belt or how exactly to disable the motor. Last edited by sugarwood; 06-28-2014 at 11:19 AM.. |
As you can see below, on mine, after you put on the retaining cup (pic 2) and lock washer (pic 3), it's impossible to "bottom out the alternator nut" It can only travel a few threads to the retaining cup (which blocks the threads behind it) ![]() Can another 3.2 owner confirm they have that lock washer in the 3rd pic? I don't see it on the parts diagram, but it looks very original with the gold plating. Also, the 10x710 belt installed fine. Just might end up with a different shims config. since it's a little wider. Last edited by sugarwood; 06-29-2014 at 10:01 AM.. |
I would remove it.
[QUOTE=sugarwood;8137955
The directions say to crank the engine before final belt tightening. What can I disconnect in order to crank the engine with it actually starting up? [/QUOTE] I think the easiest way is simply to remove the fuel pump fuse from the fuse panel in the luggage panel. (I think this would be easier than removing the DME under the front seat.) There's a nice diagram of the fuse panel in the Bentley manual. Assuming you don't have one, I'll try to describe the location of the fuel pump fuse for your '86: There are three panels arranged alongside each other. The fuse you want is in the middle panel, which is also the biggest. In the middle panel, the fuel pump fuse is the third one from the left (i.e. from the windshield, not the bumper) if you're facing the panel. Just pluck it off and crank the motor. |
Thanks, I'll give that fuel pump fuse trick a try.
Fuse seems more accessible than the DME which is buried under the seat. Do you need to remove that front seat plastic trim to get access? Last edited by sugarwood; 06-29-2014 at 11:34 AM.. |
Does this tension seem about right?
DME relay is that black box, push the seat forward, look behind and under the seat, reach in and pull it off.
You made your video PRIVATE, we can not access
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Another hint.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Do what ever you wish, after all it is your car. That said, things not what they seem. Make sure you have 6 shims.
Here are some thoughts on fan pulley assembly by the late Grady Clay (after all, what would he know?): Quote:
Cost of a new Outer pulley? About $100. Cost of a replacement alternator because you buggered the shaft? $685. Pay me now, pay me later.....
Harry, thanks for digging up the Grady archives regarding this subject. What a great forum, and I can see why Grady is so missed here.
I will add the 6th shim when it arrives, but the various damage pictured above is not due to a missing shim. It's due to very sloppy reassembly. When replacing the pulley, one should crouch down to eye level, and make sure it is fully seated on the rectangular notch. It also helps to be down at eye level to verify the shims are seated properly under the cup before replacing the nut. If any shims slip off and are not seated flush, the pulley will not seat right, and the pictured damage to the shaft makes sense. Always verify the pulley is not wobbling after reassembly. I don't feel there's any need to replace the shims or cup washer since mine are perfectly intact. The cup washer would have to be totally caved in to allow the alternator nut to actually bottom out before fully tightening the pulley. I think you'd need to use an impact wrench to get such a thick piece of metal to bend in like that! I don't see any downside to the split lock washer. In fact, it's sensible for a few reasons. 1) It better secures the nut. 2) It would theoretically help prevent bottoming out of the alternator nut, if you did indeed have a caved in cup washer. 3) Since it has a larger diameter than the alternator nut itself, it may help prevent cup bending if you overtighten it, since pressure is distributed towards the outer edge. Thanks for the info! It's been nice to talk through this one. Last edited by sugarwood; 06-29-2014 at 04:44 PM.. |
