g50 trans output oily is this normal?
Hi guys , changed the input and output , side seals on the trans 300 miles ago.
I had to take the cv's off and I find the output "flange" is oily. it is dry where it meets the trans. can it be leaking from the center bolt or is is melted Greece from the cv?
Erick
Old 09-01-2014, 09:36 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Its just the oil from the CV grease. Over time grease will separate and that allows the oil to migrate around the end cap since it's not a liquid-tight seal. No big deal.
Kevin L
'86 Carrera "Larry"
Old 09-01-2014, 10:07 AM
