Gumby (guest)
Guest
Posts: n/a
The "tack and plumb-bob" alignment check is very clever! What I am wondering is how you would know: which side should the required adjustment be made? Or is this just a high level check to see if things are ok and if not, then use the method described earlier in the article rear wheels off?
I enjoyed your comments on DIY. Have just found that my near new rear tires have premature wear due alignment and checked the install invoice and found I paid a hefty sum for "specialized alignment".
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-11-2014, 01:34 PM
Nick at Pelican Parts's Avatar
I've never used this method, so I can't offer insight. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
It'll only measure total toe per axle, not individual wheel.
Matt - 84 Carrera
Old 09-11-2014, 01:48 PM
search for "ray scruggs" he wrote a book on aligning your 911 at home
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 09-11-2014, 02:13 PM
