Jnikic's Avatar
930 rotors, redux
I've spent some time lately trying to get caught up on all the options for 930 replacement rotors. Since my application will be race-only, my ideal setup - at least until smarter minds (cough Bill cough) show me the better way - would be a slotted, floating rotor.
It seems the only setup out there that fits the bill perfectly is VCI's - gorgeous, but not exactly inexpensive.
The only other options would seem to rely on finding a 12 hole slotted rotor that could pair up with Rebel's 12 hole hat. I haven't come across anything that meets those specs, though.
So, do I:
- Bite the bullet and buy the VCI setup. If so, any experience with rotor life when used with Pagid Blacks or PFC 97/01?
- Use OE drilled rotors paired with Rebel's 12 hole hat for a floating setup ($~900/pair). I haven't had great experience with drilled rotors in the past, but ...
- Move to a non-floating two piece setup from Rennsport ($995/pair), Rebel ($630/pair) or a hybrid Rebel hat/Willwood GT 48 with slotted, curved veins ($400/pair)? If so, which and why?
- Stick with a one piece, drilled rotor and exchange lower cost for more frequent replacement.
78 911 Coupe :: E Prepared racecar :: Stock 3.0 :: Steel widebody :: 930 brakes
78 911 Targa RSR backdate :: 3.2L :: 10.5:1 Wossner pistons / Mahle cylinders :: Twin plug crankfire ignition :: 46mm PMO
Old 09-08-2014, 11:11 AM
Bill Verburg's Avatar
So, do I:
For track use slotted floating are what you want to use.
VC1 uses Colman rotors, I have a slightly larger version of thes on my heavily tracked 993, they hold up very well w/ Pagid 29, a friend mated another version of them to 993tt hats w/ Pagid black and was also very happy.
VCI is a copy of the oe floating setup and is(or at least was, I haven't seen any new ones recently) and can use the oe drilled rotors or their own Colman sourced rotors
Oe is was 12bolt, I am unfamiliar w/ their setup but at a guess they are also compatible w/ oe, You might want to check w/ them on that. If so then it comes down to price and availability.
I am getting more then double(closer to triple) the rotor life from the floating Colmans as I did w/ oe 993tt drilled
Bill Verburg
Old 09-08-2014, 12:26 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 09-08-2014, 01:59 PM
Cory M's Avatar
Coleman will custom make slotted rotors to your spec for about $150 each. So if you have hats and hardware that's probably your least expensive route.
Old 09-08-2014, 03:39 PM
