Alternator Woodruff Key Size?
Help, I took my alternator in to get tested and they lost the woodruff key.
![]() Does anyone know what size woodruff key I need? I have the alternator off and am heading to the hardware store tomorrow but I figured there may be someone who knows this answer. This is for a 1969 911T with a 2.2T motor. Thanks
Keitho64 05 GTO 00 911 C2 64 Corvair Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles |
Well, it is probably an early S.E.V. Marchal alternator ... and I am not sure if a later, higher-capacity model will use the same size, but my spare 980 Watt Marchal uses a 15 mm long key. Your best bet witll be to take the alternator to a bearing supply store rather than a hardware store -- the selection will be much greater, and they will have more experience.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Chock up a few points for a very good vendor. They found the woodruff key and called me today. I have it in my possession. If you are in the Chicago area, look up Dispatch Auto in Addison. They rebuild starters and alternators and they guys there are very helpful.
Thread Tools | |
Rate This Thread | |
