Spark Plugs
What would any of you recommend using? The car is a 69 2.0 S and will be used for classic car racing..... Was looking at Denso Iridium IW24..... Comments????
Thanks ![]() ![]() https://www.facebook.com/pages/Porsche-Fan-Malta-and-all-around-the-Globe/435916856528188 |
bosch copper supers. start with a cold plug, maybe a 5. problem could be fouling when starting but check them after shutting down before it idles, perhaps after 50-100 miles
Those plugs are not for our cars. Best to use conventional plugs , bosch or ngk
Another plug that might work is an Autolite 2626 ... a barrier gap wide range plug.
This type of plug has no projecting ground electrode...so the gap is set at the factory...and never needs regapping. Bosche used to make this same type of plug for snowmobiles...they called it the "GO plug". The real advantage of the Autolite plug?...about $2.50 each! Bob
Bob Hutson |
Thanks, Sherwood |
Member 911 Anonymous
+1 Copper NGK's or Bosch.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Those are the standard go-to plugs. For knats-hair improvement, the proper heat range surface gap plugs don't have a side electrode to shroud the spark in order to equalize the fuel burn. In lieu of these plugs, those looking for that extra edge use indexing spark plug washers to "point" the side electrode in the correct "unshrouded" direction.
Sherwood |
The manufacturer claims that it produces a stronger spark and last longer. Also seems to be a conventional plug, just a smaller stronger center electrode and U groove electrode.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Can't help re the plugs, but I can pay you a complement. Girlfriend LOVES the color.
![]() Wow.... Thanks for the help.... Will shop around to check whats available locally. At least I know what to look for. Will be back with some more pics. Thanks
Why not just go to Pelican and order the plugs for your car. Or see what they are and go to Pep Boys and buy them there. Or Auto zone.
Has anybody used NGK or Denso Iridium plugs in their 911 ?
Curious to know if they worked or not. |
Otherwise, more user experience could provide more insight. Sherwood |
RETIRED
Another vote for NGK or Bosch. Correct heat ranges can be adjusted up or down. Consider looking into ""plug indexing"......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
After a recent diagnosis from a smog test failure.
I checked out my existing plugs and found less then desirable sparks via yellow/orange colored sparks. So I bought some iridium plugs to test versus new copper plugs. The new copper plugs sparked considerably larger and more blue in color. You can test this yourself using Bentley's method.
