oil for 915 transmission Question
My good friend has an Alfa Romeo Spider and Ferrari 308 from the 70 and he uses his gearbox WITH ATF oil of GB company.
I told him that I have a problem sometimes transfer from first to second gear, he advised me before I came in for repairs and replacement of gear sync to try this oil even though it is designed for automatic gearboxes.
He says he uses this oil for about 5 years and I immediately feel the difference.
What do you say?
Does anyone have experience with this oil?
By the way I'm from Israel and I mention this because of the warm weather prevails here
Thank's
Tom
Old 09-19-2014, 12:46 PM
TheSt|G's Avatar
No.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 09-19-2014, 01:15 PM
Never in my 915.
Old 09-19-2014, 01:20 PM
83 911 Production Cab #10
JJ 911SC's Avatar
לא
Who Will Live... Will See
Old 09-19-2014, 01:27 PM
It not just that the synchros of the 915 were never designed for such a light oil, it's that the Porsche ring and pinion needs a GL5 hypoid oil and could NEVER stand up with just ATF. Transaxles that use ATF for lubrication are for transverse engined FWD cars without hypoid gearsets.
Ok, thank you !!!
I thought so too, so I consulted with you guys,
There is oil that you recommend that can fix the problem first to second gear transfer?
Old 09-19-2014, 01:32 PM
JJ 911SC's Avatar
Without starting yet another oil thread controversy... Swepco or Kendall.
If you are using one of them, try the other.
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2014.cgi?SUPERCAT_FLAG=Y&make=POR&Context_make=&please_wait=N&LastVisited_input=911M&Previous_Section=&forumid=8&threadid=337969&command=DWsearch&description=transmission+oil&I1.x=-259&I1.y=-108
Old 09-19-2014, 01:40 PM
תודה מלך
thanks
Old 09-19-2014, 01:44 PM
Under the radar
Trackrash's Avatar
What oil are you using now in your 915?
How does your trans shift when cold? Does it shift better when warm?
Cannot Get Kendall In Australia for my 915 what should I buy?
Recipe for Best Shifting 915
G50 and 915 Fluids
I use Swepco, but others prefer Kendall.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-19-2014, 01:47 PM
I should clarify, I swapped in the United States last year at Don Jackson in Arizona, before importing the vehicle to Israel.I'll ask him,
The problem in my gearbox is when I move quickly from first to second gear then there creak,
If I move slowly with a slight delay so everything is fine.
The rest of the gears are perfect, I also lowers gears no problem,
There is a problem only to transfer the first gear into second.
Old 09-19-2014, 01:58 PM
Kendall NS-MP 80-90 or Swepco 206(?). I use Kendall in the 70.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 09-19-2014, 02:42 PM
Drisump's Avatar
Every 915 that I've ever driven does not respond well to "quick" gear changes of any kind (mine included). My 915, if driven with respect and attention to rev matching, is a very nice, smooth shifting transmission (even during spirited driving). Within the lineage, the G50 has a much more modern feel, and is more tolerant of faster shifting and insensitive usage.
Old 09-20-2014, 07:17 AM
Peter Zimmermann's Avatar
You must not expect the transmission to adjust to you; it is you who must adjust. Drive the car the way it's telling you that it wants to be driven, and be happy with that. Do not ask your trans to do something that it cannot do. Speed shifting is for Mustangs and Corvettes, NOT 915s!
Keep the Shiny Side UP!
Pete Z.
Old 09-20-2014, 07:30 AM
Straight shooter
Lapkritis's Avatar
You're better off with a generic store brand, conventional gear oil than a fancy modern synthetic. What is most expensive isn't always best for the application which goes against what many of us learn when owning these things.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 09-20-2014, 08:46 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 what master Peter wrote.
If you can find it, locate some Dow Corning MOLIKOTE, drain the gear box about 3 ounces and replace with the MOLIKOTE. It will reduce the temps of the gear box and not adversely affect the gear box or the gear lube. On the next gear lube change just place 1.5 ounces of Molikote.
Please don't put ATF in the gear box. Now ask your friend to show you what his drained ATF looks like on the next change. I think you will be quite surprised. All that glitters is not gold :-D
'85 Carrera Targa
PCA/POC
Old 09-20-2014, 08:57 AM
The Porsche synchronizer system is pretty sensitive to the lubricity of the gear oil, hence all the discussion about Swepco vs. Kendall. Although Molikote might do wonders for the R&P, IMHO I wouldn't add it as out of concern for the 915 synchros.
Old 09-20-2014, 02:03 PM
gearhead
Pete describes it well, but isnt explicit enough. The 1-2 shift on a 915 requires the pause that you have discovered. Use it.
Does your gear oil even need changing yet?
Old 09-20-2014, 02:26 PM
Thank you, Mister Pete!!!!
This has been my message to all 915 owners since 1974. The ones that don't listen to your sage advice are the folks that will take a BIG hit to the wallet.
After paying the bill, they are much more amenable about listening.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-20-2014, 03:34 PM
Sboxin's Avatar
Agree with Pete, Matt and Steve . . .
We also use Don Jackson in Phoenix for our race car 915 - - Sepco non synthetic works fine.
Enjoy your 911 . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 09-20-2014, 03:44 PM
Regis turd ab user
Guy goes to the doctor and says "it hurts when I do this", doctor says, "don't do that".
Old 09-20-2014, 04:44 PM
