Need help with engine number please!
Hi all,
Purchasing a 911 and I have a CoA that lists the engine number as 620522 but the engine in the car is "6210270"
I know CoA's are notorious for mistakes but if the engine in the car is indeed original what do you do about a CoA that is non-matching? Have they ever been know to correct them?
TIA
Old 09-22-2014, 07:31 PM
E Sully's Avatar
You don't give much information to work with. COA lists a 1970 engine, you have a 1971 engine. Need the year of the car.
Ed
1973.5 T
Old 09-23-2014, 06:25 AM
Originally Posted by GreenHell View Post
Hi all,
TIA
Looks you typo'd the COA engine number as it is short one digit. As E Sully posted, we need to know the year of the car because you have a 70 engine listed on the COA and a 71 actually in the car. Assuming from your post the car is a 1970, then it is doubtful, IMO, that the COA would be incorrect to the degree that a 71 engine was put into a 70 vehicle. To my knowledge (which is certainly not extensive in this area) Porsche never put a later model year engine into a vehicle at the factory.
If the car is a 71, and you copied the shortened engine number correctly from the COA, then it is quite possible a mistake was made as the number is non-existent.
If the car is a 70, most likely the engine was replaced by a PO sometime in the life of the car. If the car is a 71, it's possible the COA is wrong.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-23-2014, 07:14 AM
