Need help with engine number please!
Hi all,
Purchasing a 911 and I have a CoA that lists the engine number as 620522 but the engine in the car is "6210270" I know CoA's are notorious for mistakes but if the engine in the car is indeed original what do you do about a CoA that is non-matching? Have they ever been know to correct them? TIA |
You don't give much information to work with. COA lists a 1970 engine, you have a 1971 engine. Need the year of the car.
Ed 1973.5 T |
If the car is a 71, and you copied the shortened engine number correctly from the COA, then it is quite possible a mistake was made as the number is non-existent. If the car is a 70, most likely the engine was replaced by a PO sometime in the life of the car. If the car is a 71, it's possible the COA is wrong.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
