Things that make you go "DAMN IT"....
Installed the headers, extensions and Dansk sport muffler..took some tweaking , got the bumper back on and then looked over in the corner and saw the rear engine tin..... DAMN IT!!
Easier to take the engine brace off (all solid mounts) than removing the exhaust again... Think I can squeeze it in this way??? |
Senior Advisor
damn it that sucks
08 Cayenne Turbo |
Damn it!
Moments like that can make you feel like your whole world is turned upside down...
Obsessed
Reinstall your just rebuilt engine (by yourself), runs, woo hoo! Forgot to align the clutch fork with the pilot bearing so the motor needs to come half way out again.....DAMMIT!
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
Brando
My dammit moments are using the apple phone and submiting sideways or upsidedown pics. Happens all the time.
Turbo powa! 1977 911s. it's cool |
Brando
I did that too. Dammit
Weird? On the IPad it appears rightsideup.
Senior Advisor
thinking the tone ring on a 3.2 flywheel is the starter ring, DAMN IT! (not me but many)
08 Cayenne Turbo |
Putting the brake calipers on the wrong side and unable to bleed the brakes - DAMN IT!
Robert Williams 70' 911T |
RETIRED
Nipples up.....like wimmen.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
install drivetrain with "new" trans in SC, go to hook up clutch helper spring...notice that trans is set up for clutch mechanism without helper spring and shaft has no place to put the spring...must drop drivetrain and separate engine/trans to install new style longer shaft.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Banned
ddinham is another one of those "types" that likes to hang his vehicle from the ceiling when working on it (and hangs the other garage stuff from there too)! Did you get some tips from quattrorunner? If not, ask him what he uses to stick his car up there!
registered woman user
walk into the garage to take my baby for a ride.......and dead as a door knob. guess i'll be checking the alternator replacement guide thread. crap
white 1986 3.2 targa 911 life is what happens while your busy making other plans
Brando
Best friend is my dog
At 70 years of age, if I take out more than two bolts I will forget where I laid them. Dammit!!
GAFB
Install 4-piston aluminum Brembos on my 928 and spend hours bleeding them. Get frustrated, check the factory shop manual.
-bleed master cylinder- check (wish my 911 master cylinder had a bleed nipple) -bleed clutch slave- check -bleed BOTH bleed nipples on each caliper- DAMNIT |
Instances too numerous to list. Latest yesterday. Changing trans oil on 70. Just started pumping first quart. Wait, there's a leak. No, forgot to reinstall drain plug. DAMMIT.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
I have the same problem, put a screw driver down on a work bench, go to grab it 1 minute later and can't see it, AND I'M LOOKING RIGHT AT IT
Sold: 1989 3.2 coupe, 112k miles |
