kcf7z's Avatar
Low Beams Don't work but high beams do
I assume this is due to the stalk switch being bad but the symptoms were not exactly what I found for the fixes in my "search" of the technical forum. I read about the contacts being the problem.
Symptoms:
low beams do not come on but fog lights do
high beams work
turn signals are erratic
Car: 79 Euro 930
I am sure this is a repeat, but those with wisdom, please redirect.
Old 10-05-2014, 04:54 AM
toddu's Avatar
Low and high are on separate fuses. Start there.
Todd
'81 SC
Old 10-05-2014, 06:10 AM
non-whiner
mreid's Avatar
Fuse and include an inspection for corrosion in the fuse holder if the fuse is good.
"Too much is just enough."
Old 10-05-2014, 06:20 AM
Happened to me last week and it was the fuse... Didn't blow, just needed to be reinserted as it was sitting a little wonky.
Old 10-05-2014, 06:22 AM
PorscheAmateur's Avatar
Check the fuse. But it could also be the switch like it was for me. For some reason my lows worked but my Highs didn't.
1980 Porsche 911SC
Old 10-05-2014, 07:47 AM
LakeCleElum's Avatar
An old thread from 2005 is your friend:
turn signal switch quick fix pictures
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-05-2014, 07:52 AM
ROW '78 911 Targa
timmy2's Avatar
If it is just the fuse, you should install the headlight relays.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-05-2014, 08:10 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Relays.
For our '86
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-05-2014, 09:04 AM
