Trying to identify engine
Good day all from sunny Cape Town South Africa.
I am trying to identify a 911 engine serial number 6113008. I need the date and specs if possible. This engine is fitted in a 356SC with a 901 gearbox. Many thanks!! |
From the "Red Book"
1971 911T Eng. SN range: 6110001-6113475 Type: 911/03 Bore: 84mm Stroke: 66mm 2.2L; 2195cc Compression Ratio: 8.6:1 Zenith 40 carbs Intake: 46mm Exhaust: 40mm 125 HP @ 5800RPM 130 FP Torque @4200RPM |
Many thanks for the info - just what I need.
Must be a happy 356C
Does that make it a 956?
78 911SC sunroof Coupe (SOLD) 97 328i Convertible |
You are welcome...sounds like a fun ride!
