Devil Dog Mosport's Avatar
Things that make you go "DAMN IT"....
Installed the headers, extensions and Dansk sport muffler..took some tweaking , got the bumper back on and then looked over in the corner and saw the rear engine tin..... DAMN IT!!
Easier to take the engine brace off (all solid mounts) than removing the exhaust again... Think I can squeeze it in this way???
Old 05-09-2013, 02:59 PM
Senior Advisor
James Brown's Avatar
damn it that sucks
08 Cayenne Turbo
Old 05-09-2013, 03:39 PM
Damn it!
Old 05-09-2013, 04:43 PM
72T 72T is offline
Moments like that can make you feel like your whole world is turned upside down...
Old 05-09-2013, 04:58 PM
Obsessed
sobamaflyer's Avatar
Reinstall your just rebuilt engine (by yourself), runs, woo hoo! Forgot to align the clutch fork with the pilot bearing so the motor needs to come half way out again.....DAMMIT!
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 05-09-2013, 05:00 PM
Brando
quattrorunner's Avatar
haha.
My dammit moments are using the apple phone and submiting sideways or upsidedown pics. Happens all the time.
Turbo powa!
1977 911s. it's cool
Old 05-09-2013, 05:14 PM
Brando
I did that too. Dammit
Turbo powa!
Old 05-09-2013, 05:15 PM
Weird? On the IPad it appears rightsideup.
Old 05-09-2013, 05:33 PM
Senior Advisor
thinking the tone ring on a 3.2 flywheel is the starter ring, DAMN IT! (not me but many)
08 Cayenne Turbo
Old 05-09-2013, 06:29 PM
rw7810's Avatar
Putting the brake calipers on the wrong side and unable to bleed the brakes - DAMN IT!
Robert Williams
70' 911T
Old 05-11-2013, 07:16 PM
RETIRED
Joe Bob's Avatar
Nipples up.....like wimmen.....
2012 ML350 3.0 Turbo Diesel
Old 05-11-2013, 07:33 PM
schumicat's Avatar
install drivetrain with "new" trans in SC, go to hook up clutch helper spring...notice that trans is set up for clutch mechanism without helper spring and shaft has no place to put the spring...must drop drivetrain and separate engine/trans to install new style longer shaft.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-11-2013, 08:02 PM
Banned
ddinham is another one of those "types" that likes to hang his vehicle from the ceiling when working on it (and hangs the other garage stuff from there too)! Did you get some tips from quattrorunner? If not, ask him what he uses to stick his car up there!
Old 05-11-2013, 08:36 PM
registered woman user
rinverso's Avatar
walk into the garage to take my baby for a ride.......and dead as a door knob. guess i'll be checking the alternator replacement guide thread. crap
white 1986 3.2 targa 911
life is what happens while your busy making other plans
Old 05-11-2013, 08:51 PM
Brando
Omg that's just too much dammit. Funny though
Old 05-11-2013, 09:03 PM
Best friend is my dog
At 70 years of age, if I take out more than two bolts I will forget where I laid them. Dammit!!
Old 05-11-2013, 10:11 PM
dtw dtw is offline
GAFB
Install 4-piston aluminum Brembos on my 928 and spend hours bleeding them. Get frustrated, check the factory shop manual.
-bleed master cylinder- check (wish my 911 master cylinder had a bleed nipple)
-bleed clutch slave- check
-bleed BOTH bleed nipples on each caliper- DAMNIT
Old 05-12-2013, 12:56 AM
I do that and I'm 50
Old 05-12-2013, 03:41 AM
Instances too numerous to list. Latest yesterday. Changing trans oil on 70. Just started pumping first quart. Wait, there's a leak. No, forgot to reinstall drain plug. DAMMIT.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 05-12-2013, 05:46 AM
I have the same problem, put a screw driver down on a work bench, go to grab it 1 minute later and can't see it, AND I'M LOOKING RIGHT AT IT
Sold: 1989 3.2 coupe, 112k miles
Old 05-12-2013, 08:21 AM
