Making Progress! Engine is in - with PMO
I'm made a lot of progress this weekend and the engine is back in the car. I still have lots of little to-do's so it will be about a week before the first startup with the new PMO EFI & Electromotive.
I'm feeling like I can see the end of the tunnel. Here's a progress pic - lots of little wires to clean up and add connectors to. When I'm finished with the entire project, I will start a "start to finish" thread with better pics. ![]() |
Slippery Slope Victim
So pretty. You'll love them.
MikeČ 1985 M491 |
Hi Vern,
Looks fantastic! Hopefully this whets your appetite. Cheers, Harry. |
Caveman Hammer Mechanic
Watch out, a Labrador Retriever left his rollers on your carb intakes.......if mine saw that he wouldn't sleep for a week!
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Next thing I do to my CIS system is this!
Hi tidyboy, I'm waiting anxiously for the start-up. Beautiful. Also looking forward to reading the whole project thread. If your going to do it, do it right. That you did, awesome.
I am planning to use the PMOs on a 3.2 ss
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
Nice work Vern.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
muck-raker
I wish I had the time, patience, energy, money, brains and balls to do something like that. In other words, it looks fantastic. Good on ya, Vern.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations ![]() |
83 911 Production Cab #10
Look good Vern.
Richard instruction for the initial start-up were perfect. http://www.clewett.com/instrux/TUNING%20PROCEDURE.pdf
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
If only I could go a little faster and get this finished. I have committed myself to two hours per night to get it wrapped up but then I've ended up working late every night.
I can at least report that I have cleaned my garage and I'm ready to finish the job. The only open items are to finish terminating sensor plugs, install the front & rear sway bars, finish the wiring for the fuel pump moved to the front, mount the fuel filter & fuel pressure regulator, adjust the rear alignment to get back to my markings (everything got moved during rear bushing replacement & I finally found & bought the correct allen wrench to make adjustments), Install front seats & shifter. Now, if I can't get all that done in the next week or so, something is wrong with me! |
You'd be surprised at how little I can get done in a week working a couple hours every night. Worlds slowest mechanic!
Thread Tools | |
Rate This Thread | |
