Rennch on YouTube
Distributor Recurve Question
My R.O.W. 3.0 engine has had an early (smaller gear) distributor fitted to it. (It looks like a carrera, but it's not)
Here's a picture of the distributor: ![]() It's got a little "target" on the side with "32" in it. I'm switching from CIS to carbs. Do I still need to recurve this distributor? And...will the car run without recurving it in the short term? Thanks! Michael
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
It depends on what distributor you have. Some of them you can simply disconnect the vac and set more initial timing.
I typically re-curve them to a modified RS curve. Total curve comes in sooner. The "32" is a casting date. The part number is stamped on the other side.... 0 231 184 xxx
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Rennch on YouTube
That's great news. Thanks!
SC's had a counter-clockwise distributor rotation. Earlier distributors were set for clockwise rotation. Which way is yours spinning, and what is the number on it?
Ed 1973.5 T |
Fleabit peanut monkey
Type as in 930-XX
1981 911SC Targa |
He most likely has a carrera 3.0. It ran a 2.7 style distributor and was clockwise. Or, someone installed a cw gear on the crank.
You would not be able to install a cw distributor in an engine with a ccw crank gear |
