Lambda System functioning ?
Well, after a week of Fuel pressure testing and getting my feet wet on the 1981sc Lambda CIS system, I find myself wanting to verify that my Lambda system - from 02 sensor to ECU to FV etc. is working as it should.
When I purchased the car two years ago, I discovered that the ECU was not connected. Since then, the motor has been rebuilt, installed and "dialed in" by a shop that advertises itself as Porsche specialists. They installed a new 02 sensor, reconnected the wiring harness and stated all was working fine. While the source of my idling and start problems may indeed lie elsewhere, it has been advised that after verifying cold, warm and system pressures, it is now time to verify all is well with the Lambda system (I have a digital WUR installed, and have been working with the company owner to verify IT'S proper operation up till now... ). My question is what is the best way to go about this systematically. Start at the ECU side or the 02 side ? What are the best test equipment and procedures to employ ? So far I have changed out the 02 sensor relay at the ECU, checked to be sure that the 12 (13?) pin harness connectors are installed and engaged, disconnected and reconnected the FV connector and examined the 02 sensor itself, and it's connection to the pin connector inside the engine bay (see photo). In doing this, I did notice that the 02 connector as well as it's wire leading to the harness had both seen better days. It looks as if the aforementioned harness lead has chaffed a bit over the years (although it may still be functional as it is ?). Also, the plastic surrounding the wire at the pin side, looks damaged (the pin has been removed due to looseness, and will be soldered on again if this unit is deemed usable). So, the questions are, 1. Should I be looking at replacing the above mentioned connector and/or lead ? and 2. How should I go about my testing procedure to verify that everything in this Lambda system is working ? While I am a relative newbie to the CIS system, I have done a bit of research on it including reviewing the Primer on the system, a number of Pelican posts and the Tech BBS on the subject. I have a voltmeter, vacuum pump/gauge as well as a CIS tester at this time (I also have a determination to understand this magnificant bastard of a fuel system, and get it all on the same page with itself !) Anyway, all comments, advice and suggestions are thoroughly appreciated ! ![]() Cheers all, and thanks you. [img]http://forums.pelicanparts.com/uploads24/02+sensor+connector+and+wire1413359670.jpg[/img |
You need to connect an analog dwell meter to the test port under the plastic cover in the engine compartment to "see" what the lambda system is doing under differing conditions. Everything you need to know is in the archives, try searching for CIS lambda. Stumbling and stalling after cold start is usually caused by weak mixture from vacuum leaks, the vacuum retard and using other than BOSCH normal spark plugs. The O2 sensor is irrelevant to cold starts but the ECU and pulsing FV are not, they must be at the default duty cycle.
Paul |
Thanks Paul.
I have not used a dwell meter before. Where might I find one ? Will doing this test tell me whether the ECU and FV are working and pulsing correctly ? If they are, do you suspect an unmetered air leak(s) ? |
And by the way, after a reasonably good cold start and 1,200 or so idle for about 40 secs, the motor then slows to 950 or so for another minute and then will slow and stall if not throttled until fully warm. It then idles fine (with a very regular +50 rpm every couple of seconds). After 20 mins of sitting, the car will not idle at all again without throttling, until once again fully warm. It needs to sit until fully cold before once again cold starting as first described.
Best, Bill |
i would want to know what the fuel pressures are.
check the freq of the FV as said if i could, check the AFR's
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Somewhat obsessed......
Frequency Valve
Have you verified that the frequency valve is working? It has a very pronounced buzz when functioning. It doesn't work till the engine is running or you jump the fuel pump relay, ignition key on. A brief search will give you the procedure for jumping the relay. I just use a couple roofing nails and a alligator clip jump wire. I think you jump 87a and 30. I always double check my reference first though.
If your car was running with the ECU unplugged, they may have richened the fuel mix to compensate for the lack of cold start enriching. Then as it warms, the engine is way too rich. Just a thought. Also check out Jim's "CIS Primer". It covers about all of what ails us.
Chris '83 Super Carrera ......There are many like it, but this one is mine. |
Note to self, RTF post.
Sorry, I see that you already read that!
Bill,
My advice would be to borrow one, anyone who works on cars with points will have one lying around. It sounds like your car goes into closed loop when warm , but why guess ? My advice would be to first disconnect and unplug the gray vacuum retard hose at the back of the distributor and reset the hot idle to 950 rpm with the large thumb screw on the throttle body. This usually greatly improves start up issues. If you have gauges, check the pressures against the manual specs, but a CIS lambda car can have perfect pressures and run like crap. Check the ignition timing with both hoses plugged, 5 BTDC @ 950 rpm. Then drive the car for 10 miles and check the hot closed loop dwell.
Paul |
One simple test with engine fully warm is to use a good digital volt meter that can read well in the 0-1vdc range. Then simply measure the voltage at the O2 sensors signal line. If the system is functioning the voltage will swing between .2 and .8 vdc if you can clearly see this swing in voltage the system is working. If it reads a constant less than .5vdc the engine is running very lean and the system can't richen it. If it reads constant more than .5vdc then it's running rich beyond what the system can do.
And if you can get a oscilloscope you can really see that the signal is a sine-wave that swings from .2 to .8dc a few times per second. As the sensors age they respond slower and the swing takes much longer. In Summary; measure the sensor's voltage with engine warm and report back.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Thanks all for the very valuable information.
I like to do the easy, simple things first so I will be checking for the buzz of the FV first, then move on to some basic voltage reading to verify duty cycle. Paul, check me if I am wrong, but with the Electromotive HPV-1 distributorless ignition system that I am running, there is no vacuum advance. As you might know, advance is set in three straight line and additive rpm ranges (up to 1000, up to 3000 and up to 8000) there is also an over rev limiter setting. Mine are set at 5, 19 and 6. |
Hey Bill,
Sounds like your lambda SC is far from stock, digital WUR and crank fire ignition ? You are probably by yourself with that combo. No vacuum advance or retard unless you have a MAP sensor. If I read you correctly, you are using 30 BTDC timing after 3000 rpm which is 5 degrees more timing than stock. I would be using the highest octane fuel available and be listening and looking for signs of pinging. If you have good fuel and the motor does not run hot, you may be able to get away with it, but the small port SC is tuned for a low rpm torque boost and is very knock sensitive. How did the pressure readings compare to the warm up curve in the factory manual ? The dwell meter will show you how much the system needs to alter the lower chamber pressure to get to closer to stoich at idle. Voltage at the O2 sensor will not give you the information you need to make mixture adjustments at the FD. If you still have the stock throttle switch, the system goes open loop and ignores the O2 sensor after 35 % throttle. What controls your digital WUR ?
Paul Last edited by psalt; 10-15-2014 at 12:48 PM.. |
Thanks Paul,
The WUR powered just as the stock one was. It has a MAP sensor included in its digitally controlled motherboard. It has an electrically actuated injector that mimics the original WUR injector that was controlled by the bimetal strip. My system pressure is 4.6 bar and cold control pressure is 2.2 bar. I am working with the WUR manufacturer now to program the correct warm pressure cycle but that is another issue. As for timing advance. Up to 1000 rpm I am at 5, the system then advances evenly up to 5 + 19 = 24 at 3000rpm. It then rises 1.2 degrees per each additional 1000 rpm up to 8000. Since I do not plan (and have a rev limiter) to go beyond around 6,800 rpm, I believe the advance should be limited to a total of 24+(3.8 x 1.2) = 28.5 total advance. At least, this is if all is operating as it should. I have 91 octane here and am always listening for detonation. One thing in my favor here is the relatively high power output of the crank fire coils. Am I wrong in thinking that this should help mitigate detonation some ? Anyway, this is getting a little off track .... |
Bill,
I don't think detonation is mitigated by spark energy and the coil only supplies the required voltage to jump the gap. The stock CDI has more than the required voltage. I have run 28 degrees of timing on an SC, but you need to watch for detonation. Ok, if you are new to lambda CIS on a 911, here is the super condensed, almost incorrect, but necessary way to think about it. It is a basic CIS system that is calibrated too lean everywhere, that uses the FV the richen up the mixture everywhere, using a default FV pulse open loop and above 35% throttle and the O2 sensor feedback loop below 35% throttle. If the ECU loses power and/or the FV stays closed, it is too lean everywhere and it cannot be correctly adjusted out. If your pressures were in spec and the FV was closed it would run like crap. In other words, the limp home settings are just the opposite of what you would expect from BOSCH, too lean, but at least it limps with a failed ECU. Also when reading duty cycle, higher is richer when in open loop, but high is leaner in closed loop. This is because in closed loop, you are looking at the systems reaction to the O2 reading, a high reading means the system is trying to adjust a too lean condition. For a richer open loop WOT mixture, you want a lower closed loop duty cycle. OK ? The original cold control pressure spec was 1.4-1.8 bar at 10C rising to 3.4-3.8 bar at 40C (2.2 bar is around 20C). Warm pressure should be 3.4-3.8 bar, do you have that ? System pressure is 4.5 -5.2 bar. Have you tested how quickly your control pressure rises against temperature ?
Paul |
I like super condensed .... Just so that I understand, when you refer to open and closed loop, are you equating that to a functioning FV and a non functioning one ?
After monkeying with all of the harnesses and connections, I do in fact hear the FV buzzing (I do not believe this was the case during my initial fuel pressure testing). I unplugged it and tested the voltage to it and it was steady at just under 12v. At this point, I am reconnecting the 02 sensor connection in the engine bay, because (as I understand you?) the ECU needs feedback from the sensor (at idle and below 35% throttle) to properly enrich the system ? Of course, this would be with a running motor correct ? So far, I have done the aforementioned tests with the FP relay socket jumped at terminals 30 and 87a. As such, when I pulled the FV valve connector, I measured the voltage as a steady reading that was just under 12v. Is this normal ? Should it be at a lesser duty cycle even with a non running motor ? Next step/test ? Thank You Bill |
Some further results ...
I repaired and reconnected the O2 sensor connector in the bay and retested the FV voltage and it was still pegged at around 12v. Perhaps with a running car and an active 02 signal, this voltage would drop to a more appropriate duty cycle (if I understand things correctly ....) ? I then started the car with a buzzing FV (do not believe this was the case previously, when the folks who installed and "dialed in" this newly built motor 2,500 miles ago). I should mention that - upon other things - the installer had a non-functioning MAP hose connected to the WUR as well as the likely non-functioning FV and "dialed in" the mixture accordingly .... I now believe I am dealing with a different animal. Once the car was warm ( I had to increase the idle a quarter turn to keep it idling during warm up), my control pressure was at 3 bar (I know, low) and my 02 sensor output voltage - yes, I remember Sals sage advice - stayed at around .1 volt at idle and rose to a steady .4 volt when I gunned it. I am wondering what my next steps are ..... continue testing the ECU side of things or focus on the WUR pressure issue. Thanks to all, I could not be more appreciative of everyones input . Bill |
Bill,
You are shooting in the dark without actually testing the duty cycle. You need to determine if the ECU is pulsing the FV in the correct range open loop and dithering in closed loop. The open loop operation (cold and WOT) cannot be tested at the O2 sensor. If your new O2 sensor produced 0.1 volt with a low 3 bar control pressure, about all you can say is the sensor is not broken and it is lean when it should be rich. Is it lean because the ECU is not pulsing the FV correctly ? The unheated narrow band sensor in an SC is not very accurate away from 0.5 volt and should be viewed as a switch. Have you tested the main temperature switch on the right timing chain cover ?
Paul Last edited by psalt; 10-16-2014 at 02:48 AM.. |
Bill, Missed that one. No, closed loop is when the mixture is controlled by the O2 sensor input. The "closed loop" is, fuel injected-combustion-exhaust O2 content measure-fuel injected adjusted, lather, rinse repeat and so on. Open loop is when the amount injected is not altered by the O2 sensor, it is a default value from a table. The key point many people do not understand about CIS lamdba is that the FV must be pulsing all the time, under a fixed default value(s) open loop and dithering around stoich when in closed loop. The goal with your motor should be optimum open loop AFR under WOT, decent cold start, then let the lambda pull the mixture back to 14.7:1 for low load part throttle cruise (85% of road driving time) . You are probably measuring average voltage at the plug which really doesn't tell you anything.
Paul |
Thanks as always, Paul (and anyone else).
Decided to invest in a new digital volt meter (Klein tools MM200) that has a duty cycle dwell and % function. Jumpered the FP relay socket at 30 and 87a (key at on) and checked the 3 pin test connector in the bay. The green and while lead pin checked in at a steady 50%. As it was 75 degrees F at the time, I checked the 59 degree F temp switch for open state by using a continuity test light on the disconnected tab (correct test ?) and there was no light as expected. I also verified my cold control fuel pressure at this time was steady at 2.2 bar. I then started the motor (with some difficulty, but it did idle). The control pressure stayed at the 2.2 bar reading until jumping quickly to around 3bar after around 40 seconds and stayed there throughout the next 10 minutes of idling/warmup. When the temp (at the left chainbox cover) was around 160 degrees and the motor still idling, I disconnected the 02 sensor connection and tested the duty cycle again and it was still pegged at 50%. I also (unlike last test) disconnected the 02 sensor connector from the sensor itself and put my new dvm to the sensor lead itself. Nothing .... no voltage at all. I checked on another circuit to be sure that my meter was functioning correctly and it was. The wires seem well connected to the actual sensor, and it was new 2,000 miles ago so what gives ? I am tempted to remove and replace the sensor, but I am not sure if there is a good way to test the thing (and repair ?) first. Also, what sensor is the best one to replace it with (brand, wide or narrow band etc.) ? At least I am making some progress .... Best, Bill |
Bill,
The main switch is normally closed and opens when hot. The Bentley manual has this backward. The 59F/15C refers to the temperature of the engine, not the air. The factory switch has a round terminal, but some cars have the "upgrade" higher temp superswitch which opens at a higher temp. It has a flat terminal. If the O2 sensor is not producing a valid signal, the system will not go into closed loop even if the main switch works. The sensor may be carbon fouled, you can take it out and clean it with a torch. You cannot use a heated or wide band sensor with CIS lambda, just the single wire BOSCH, which can be found for $20 if you are willing to splice the wire. The shielding is necessary, it is a long way for 0.1 volts to go. It sounds like you verified the ECU is pulsing the FV at the default setting. It also sounds like your digital WUR is wacky and raising the pressure too soon, do you have the original WUR ?
Paul |
Well .... I bought the car with the CIS mods already on it so while I do not have the original dizzy and WUR, I did have the forethought to buy another pelicans used WUR (same year U.S car) just in case. I had it tested by Tony on this forum, and he concluded it needs a refurbish. Since I was waiting on a brand new digital WUR at that time, I decided to save the refurbishment for later .... I have been told by the DWUR tech that once I have the rest of the CIS system components functional again, it should be an easy software update in order to produce the desired cold - to - warm control pressure and rate of delivery defaults on my unit. Why this was not done by the installer who assured me of his ability to "dial me in" (and proved it by his premium priced invoice ), I can only guess.
By the way, I mentioned previously that the WUR did not have a functioning vacuum hose connected to it (the one the installer connected had no active vacuum), but that I had found one just below the fiber jacketed one that he used, that did have a vacuum that I tested to be around 15-20 bar up to around 2 to 2.5 thousand rpm, and then dropped to zero. Does this sound like the kind of vacuum input I am looking for for a typical WUR application ? It is the one that is connected now. As to the 15 C temp switch, mine is gold colored and has a flat tab coming from it as a connection point for the wire. Are you saying that at the cold temperature (I measured it by shooting a laser thermometer at the base of the switch) of 75 F , that the light on the continuity tester SHOULD have lit when tested at the disconnected switches flat tab ? Also, am I correct in assuming that the lack of a readable voltage measured at the 02 sensor was probably not because the mixture was set at a ridiculously lean mixture, and that it was more likely malfunctioning ? I also did not see any shielding whatsoever on the lead running from the sensor to the connector .... just a small diameter black wire. And yes, the same folks installed the new sensor at the same time they installed the digital WUR. Lastly, when I do get this digital WUR programmed, what would be ideal cold and warm - and rate of transition between the two - control pressures ? Fun, fun, fun .... Thanks ! Bill |
Thread Tools | |
Rate This Thread | |
