Fleabit peanut monkey
Agree. Very thorough work throughout the three threads.
1981 911SC Targa |
You may well have hit on the kindling answer. (Yes... car in my possession only.) It's very possible that resistor was out for a while. I simply can't remember but that would seem to be the ONLY way for foot rest wood to get in there. Damm fine thinking Will. Am calling that mystery solved.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
A slow, "low velocity", leak via the Schrader valve would not "carry" the "clear to see" refrigeration oil which would otherwise indicate a leak.
If I remember correctly some of the early pictures did show evidence of abuse around the mounting screw holes for the inlet/resistor duct. Last edited by wwest; 10-15-2014 at 02:03 PM.. |
Banned
Nice write-up, Karl, and really a fine and determined effort to stay the course with this despite the many battles between the mobile a/c experienced and the mobile a/c inexperienced that stunk up your previous threads (which I acknowledge having a MAJOR role in).
This is a great summary and photo-documentation of your earlier threads. I am very glad you now have excellent performance from your a/c. I suggest your next thread should be 'A Summary or Guide to the Summary of "My a/c Burns me up"'.
Great job, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Good to see your back Karl!
I agree,a great guide and I would go a step further and recommend a more direct thread title like aircooled a/c .The bible ![]() Also, this is one of the most important things learned from this was to USE the thermostat control, before, like probably most people when it got too cold I would turn the blower down rather than turn the thermostat up. When the air starts coming out below 40, just turn the temp up a bit , works perfectly without freezing the evap. Cheers,
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
With a fully functional system provided the T-stat is properly, correctly, calibrated and installled correctly the evaporator should never freeze up. |
I'm glad you finally got the results you wanted, Karl. Now, of course that summer is coming to an end, I finally got the last parts to finish rebuilding my system.
Banned
Best friend is my dog
Ronnie, as soon as my wife and I return home from our trip I believe I can help you out. I will need to start my 911 as it has been sitting idle for awhile so, I will make sure the exhaust is pointed toward Texas when I crank it up. Maybe it will blow some of our cool PNW fall weather your way. Suffer sucker....ha ha ha.
Temps never got over 85 all summer in Rockwall. Word to your Mother as Vanilla Ice says. (Am I dating myself?)
1981 911SC Targa |
Banned
UnRegistered User
Nice work. Good write up.
Glad to have been able contribute in a (hopefully) positive way.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
You'll see snow later today.Good time for 29 degree "gas story." If you will, a detailed song & dance on your method would be excellent. Am curious as to what special treatments you might be managing. Obviously you're doing more than a few things right.
This is a really great write-up! Congratulations on seeing it through and taking the time to detail everything!
Slightly off-topic - I found the single best thing I did (quick/cheap/effective) was to line the frunk with sheet rubber draught excluder. Just cut to fit and not even glued in, so I can check for condensation underneath it. Amazing how much outside air gets through the dash and fights with the cold AC air. You wont believe the difference! ![]()
1982 911SC Wine Red Metallic OMG I love this car! Last edited by Algernon; 10-21-2014 at 08:58 AM.. |
Banned
Bob, one of the few times when you will NOT hear me squalk about the heat is when I am cruising in my icy, pimp-hand machine! And you are confused there, buddy boy - you meant to say that it never got BELOW 85 in Rockwall this summer!
Gary, whatever you do, please refrain from sending a PNW fart this way - would be a very un-cool thing for you to do, sir! Karl, the only snow I might see around here would be glorious snowflakes firing out of my car's a/c vents! Getcha suuuummmmm, bub!!! PS: will do about writing up my pimpolicious charging technique when I have a chance. Last edited by Ronnie's.930; 10-21-2014 at 10:59 AM.. |
Banned
Algernon, that is a really good idea and I plan to shamelessly copy you at some point!
