Zack
car-nut's Avatar
Porsche Crest Rear wheel hight/alignment question
Dear experts:
I have the following short question in regard to red wheel alignment/height of 82 Porsche 911 SC. I would appreciate receiving your answers to my questions:
1. How much of change in height can one achieve with the rear wheel height adjustment bolt, without removing the rear wheel spindle off?
2. According to my measurement, I would need a 36 mm thin wrench to move the height adjustment bolt; correct?
3. In order to set the camber, do I need to loosen the height adjustment bolt and ride-height securing bolts (I am pretty sure I should)? Do I need to loosen the toe bolt as well.
4. And to set the toe; is it same as in 3 above?
Thank you for your time.
The car-nut.
The car-nut!
2007 Porsche Cayman-S
1982/86 wide-body 911 Carrera
1959 Triumph TR3
2004 Harley Davidson Deuce
Old 10-20-2014, 05:01 AM
If my memory serves me right.......
Originally Posted by car-nut View Post
Dear experts:
The car-nut.
1). If you have the OEM adjustable spring plate, it as about 3/4" (less than inch) max. range in adjustment.
2). 36 mm wench.
3). No. But has to loosen the toe-in bolt.
4). Yes. The key is keeping the cam of the other bolt from moving. For example, if you are adjusting the toe-in, the camber would be slightly changed and vice versa.
Tony
Old 10-20-2014, 05:43 AM
Zack
car-nut's Avatar
Short and sweet!
Many thanks.
The car-nut!
1959 Triumph TR3
Old 10-20-2014, 01:15 PM
