What is the best way to clean baked on oil from a SSI exhaust
What is the best way to clean baked on oil from a SSI exhaust?
Old 10-22-2014, 06:41 AM
Paste peanut butter on it and let your cat lick it off. ;-))
Seriously, though, I'm curious too.
- Mike
Old 10-22-2014, 07:51 AM
Banned
Since SSIs are stainless steel, I am guessing that oven cleaner will work. I have not done it, and I have not read of anyone who has, but here's how you can try it out: Get spray on oven cleaner, the kind with some sort of strong base in it (sodium hydroxide, potassium hydroxide, calcium hydroxide, etc). Spray a place on the exterior portion of the SSI that you can watch. Leave it there for a bit, then wipe it off. This is the test - if it eats the stainless steel at all, then don't use this stuff! But it shouldn't. You should be able to get off all the oil, in and out, using oven cleaner. You could also call Dansk and ask - they make SSIs now.
Old 10-22-2014, 08:09 AM
Because the temps on the HEs aren't that high, I would worry about fumes (possibly toxic) generated as the residue from the oven cleaner slowly burns off.
The Cap'n
Old 10-22-2014, 08:53 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
I have used Easy Off oven cleaner with good success. It took a few applications to get all the baked oil off but it all came off. To ensure no fumes, I rinsed them with water to remove any residue. After they were re-installed I had almost no issue with fumes in the cabin and what little there was disappeared in a few minutes.
1986 Targa Guards Red
2021 MT09 SP
Old 10-22-2014, 09:14 AM
Soda blasting. Totally non-destructive and usually very effective.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-22-2014, 09:15 AM
Taking it apart is easy
Jerome74911S's Avatar
Can any of these things - oven cleaner, soda blasting, or? - be done with the SSIs on the car?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 10-22-2014, 09:19 AM
T77911S's Avatar
i am thinking about spraying some of the carb cleaner that comes in a 1 gallon can that you soak parts in on my gear box and parts of my engine block. that stuff is VERY potent. DO NOT let it get on rubber or anything painted, it will eat it.
what ever you put on there is going to smell bad once you start it back up.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-22-2014, 11:56 AM
fred cook's Avatar
Cleaning SSIs..........
When I rebuilt the engine in my SC, I cleaned the oil and crud off my SSI exhausts using a combination of brake cleaner, parts cleaner and a scrub pad. It took a while, but they turned out pretty nice. The key here is patience.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 10-22-2014, 12:23 PM
Banned
The Cap'n
If rinsed off with water, there will be zero fumes.
Old 10-22-2014, 12:30 PM
Oven cleaner, barbecue grill cleaner, and like cleaners work AOK, but they work MUCH better when the surface to be cleaned is VERY HOT! (i.e Easy Off, you heat the oven per directions.) Heat the SSIs with a propane torch for a few minutes, then apply, being careful to avoid the fumes. Get a gallon jug of restaurant kitchen grill/stove cleaner from a restaurant supply store. (that's what I use for heavy duty burned on grease cleaning)It's very strong stuff, but when rinsed off with water, it's perfectly safe.
I take aluminum frying pans with years of baked on grease on their bottoms (kinda like your problem)
heat quite hot on the stove, turn upside down and brush on restaurant grill cleaner, and the grease just bubbles loose and flushes off with water. With no damage to aluminum, it sure won't affect stainless steel!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 10-22-2014, 02:11 PM
E Sully's Avatar
I used a soft wire wheel in my drill and it came out great.
Ed
1973.5 T
Old 10-22-2014, 04:01 PM
83 911 Production Cab #10
JJ 911SC's Avatar
On my HE box before I got the SSI. But I found a better one. Check this thread: http://forums.pelicanparts.com/cleaning-detailing-polishing/550748-best-cleaner-bar-none.html
Originally Posted by JJ 911SC View Post
Before
Use with a 3M green pad
5 hours during a rainy Saturday morning
Result; Priceless
Shower Cleaner: Clean Shower, Shower Cleaning | Seventh Generation
Who Will Live... Will See
Old 10-22-2014, 04:27 PM
100 LL Av gas works great also....
1977 911S silver/black
Old 10-24-2014, 03:15 PM
gearhead
There was a guy recently, I think in the 930 forum, who had his whole undercarriage, engine and all soda blasted. It was gorgeous. Might try searching for the thread.
Couldn't help on who might provide such a service.
Old 10-24-2014, 04:21 PM
Old 10-24-2014, 07:45 PM
83 Targa
Drive it a lot and heat, road debris and dust will eventually remove it.
If that does not work, use kerosene to clean everything.
Old 10-24-2014, 07:55 PM
Chain fence eating turbo
Quote
I remember dry ice, someone doing, but it was crazy expensive.
Old 10-24-2014, 08:35 PM
