bcgreen's Avatar
Another timing question
The purpose for checking your timing at 6K is to see if your dist. is working properly. If you're dist. is functioning properly you will not need to make changes to your timing from when you set it at idle. Am I wrong or correct?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 10-31-2014, 01:27 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Absolutely correct as long as you check it at 6k rpm.
1981 911SC Targa
Old 10-31-2014, 06:18 PM
'73 911 T Targa
And what if it doesn't show 30-35BTDC at higher RPMS. Does this point to a distributor problem? (sounds like it). Any info available for diagnosing the advance mechanism in the distributor?
Old 11-01-2014, 06:28 AM
Since we're asking questions, my Porsche spec book(1977) doesn't list an advance spec at all, just an idle spec. Is 30-35 still a good number to go by?
Rutager West
Old 11-01-2014, 06:37 AM
E Sully's Avatar
35' should work fine. This is from the Bentley. Besides the weights moving properly, part of the setting depends on the vacuum pod. If it is leaking or not moving properly it will affect your timing. It is also important to see if the correct distributor is installed. The '77 California distributor has a more radical effect then the earlier ones.
Ed
1973.5 T
Old 11-01-2014, 10:00 AM
bcgreen's Avatar
Still I am asking, do you still need to check it at 6K, is it really necessary when your dist. is finei?
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-01-2014, 10:41 AM
E Sully's Avatar
Yes.
Ed
1973.5 T
Old 11-01-2014, 03:04 PM
'73 911 T Targa
How does this change when there's no vacuum advance? My car was converted to Webers and now has no connection to the distributor's vacuum advance. Does this mean I should use something other than the 5º ATDC mark as recommended in the tech spec book when adjusting the timing at 900rpm?
Old 11-01-2014, 05:33 PM
Just use the 6 k then see if it is close at 900 rpm
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-01-2014, 05:39 PM
Bob Kontak's Avatar
In theory, no, you do not have to check it.
As soon as we say it's all good and bank on what you say, when you experience detonation or lose performance because something in the mech advance is not right, we steered you wrong.
If you had a wimp max advance like in the SC, who cares.
1981 911SC Targa
Old 11-01-2014, 06:18 PM
E Sully's Avatar
If the recommended timing at idle is with the vacuum line attached, and you are not using it, then timing at idle will be different. It is also important to check to see if the distributor is the original. If a you or a previous owner changed to a different distributor, things may change also. The most important thing to check is that maximum advance is not exceeded.
Ed
1973.5 T
Old 11-02-2014, 05:08 AM
bcgreen's Avatar
One last question: can I manually rotate the engine so I can put a paint mark on the notch?
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-02-2014, 08:38 AM
E Sully's Avatar
Yes you can, but only clockwise, don't rotate counterclockwise.
Ed
1973.5 T
Old 11-02-2014, 02:49 PM
bcgreen's Avatar
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-03-2014, 08:57 AM
