Storing a 911- Add a kill switch?
Hi,
i purchased my 911 a few months back and now with winter approaching she wont be moving for a while. My concern is the battery draining, i guess i can just unplug it but i'd rather do something more convenient. Is a kill switch a good option? Or do I do a battery trickle? Any other better options?
Old 11-06-2014, 05:59 AM
Most people put them on a trickle charger. There are several threads devoted to ideas for winter storage. I won't try to repeat all of the info, but most have a theme of:
- Trickle charger for battery
- Inflate tires to higher pressure to avoid flatspotting
- Fuel stabilizer
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 11-06-2014, 06:35 AM
AVIMAX's Avatar
Don't use a regular trickle charger, that will kill your battery. Use something like a Battery Tender, or a CTEK battery charger, they are designed to maintain your battery. You can keep them plugged in to your battery for the whole winter and you don't have to worry, the battery will be good in the spring. I use it on my car year round, I just plug it in whenever I'm not driving the car for more than a few days. I've been using a Battery Tender for at least 10 years on my cars for winter storage and never had battery issues. The only other thing I do is make sure the fuel tank is topped up to limit any condensation over the winter. My Porsche is usually parked mid Nov - mid March.
'86 Carrera Targa
'74 MGB
Old 11-06-2014, 07:30 AM
scarceller's Avatar
If you really don't plan to use the car at all for a few months.
Just fully charge it, disconnect it and if possible remove it from the car and set it in a dry space on a block of wood.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-06-2014, 08:05 AM
OsoMoore's Avatar
I pull the battery out of my car and put it on a Tender in the basement to keep it from getting really cold. My garage is not heated.
I also do the fuel stabilizer in a completely full tank of gas. So far I haven't had any real issues in the spring.
I'm in Milwaukee, so it gets close to 0 at times throughout the winter.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 11-06-2014, 08:06 AM
FrenchToast's Avatar
This.
And not directly on concrete - it will discharge.
A cutoff switch is a good idea, but primarily for other reasons IMO. If you do choose to install one, it should be a stout unit, not a dinky thing.
Fill gas tank. Stabilizer if you want. The ethanol mixture now in most gasoline, if let to set, can condense forming water and then corrosion.
Nice 3.2 But your tires look pretty old?
Old 11-06-2014, 09:04 AM
In the 16 years I have owned my SC, I have never disconnected the battery nor have I used a battery maintainer over the winter. In the spring, it starts right up. Of course, the only current draw is from the clock, which can't be much. Later cars may have more current draws from alarms and such, so your mileage may vary.
Hugo
Present: 1984 928S/Indischrot, 1994 968/Polar Silver
Past: 1979 911SC Targa/Petrol Blue
Old 11-06-2014, 10:10 AM
porwolf's Avatar
A lead-acid battery, common car battery is best stored fully charged. With age it will disintegrate if not fully charged. Even if not connected a battery will slowly lose charge. For longer storage I would take the battery out of the car and frequently charge it up or put it on a battery maintainer.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 11-06-2014, 10:32 AM
Straight shooter
Lapkritis's Avatar
Longer winters in northern states mean we're off the road for 7-8mos of the year. I always do this:
1) Gas Stabilizer
2) Fill tank on top of stabilizer and then drive for ~20mins to ensure it's diluted and distributed throughout the fuel system.
3) Wash, wax and detail car.
4) Air up tires.
5) Place dryer sheets / Fresh Cab in the three compartments.
6) Mouse traps in the three compartments (bonnet, passenger cabin, engine bay). Ensure traps are on a disposable surface like cardboard or cookie tin so you don't ruin your carpet if you score a kill. Don't use bait... they'll die in the car hiding and you'll live with the stench for a couple years. Check the car once a week or two for visitors.
7) Remove battery from vehicle and move to warm location; connect to battery tender. Harbor Freight sells one cheap that works well. I make a practice of labeling batteries for all that I have on the shelf with a trickle.
8) Remove floor mats, vaccuum, and place in bag under bonnet.
9) Open glove box and remove contents.
10) Cover vehicle, set security.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 11-06-2014, 10:58 AM
You guys are great! Thanks for all the info.
Old 11-06-2014, 11:02 AM
tharbert's Avatar
Hey 5ickride, maybe over the winter, you can drop that puppy from rally height. Just sayin'
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-06-2014, 12:26 PM
gtc gtc is offline
abides.
gtc's Avatar
But that takes the fun out of rallying it!
(ok, mine's actually a bit below euro height)
Graham
1984 Carrera Targa
Old 11-06-2014, 12:47 PM
ghamilton's Avatar
Since we are talking winter storage. Do NOT set e brake! Once in a while hop
in and depress the clutch and brakes a few times. I roll her forward and
back a few times to free up brakes.
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 11-06-2014, 01:39 PM
Straight shooter
Lapkritis's Avatar
We have our first winter storm warning tomorrow. That means I'm going to drive it around tonight for perhaps the last time this year. I plan to fill with up on non-ethanol gas in the tank with stabilizer. This brings me to another point - if you're in lake country then ask around the marina for a non-ethanol blend/ straight gasoline source. Where I'm located we have two such distributors at the pump in a 5mi radius.
Old 11-06-2014, 01:45 PM
Lol...i thought of going the other way, filling in the gaps with bigger wheels
Nice setup there
Old 11-06-2014, 01:47 PM
Straight shooter
Lapkritis's Avatar
I hear you can't lose with 22's.
Old 11-06-2014, 01:48 PM
"In the 16 years I have owned my SC, I have never disconnected the battery nor have I used a battery maintainer over the winter. In the spring, it starts right up. Of course, the only current draw is from the clock, which can't be much. Later cars may have more current draws from alarms and such, so your mileage may vary.
Hugo"
And in doing this allows for some mountain fun on a sub 30 degree sunny day...
1984 Carrera Targa
Old 11-06-2014, 01:54 PM
Right on! My criterion is salt. As long as there's no salt on the ground, I'll drive it.
Hugo
Old 11-06-2014, 03:49 PM
I just installed the Rennline kill switch and put in an Odyssey battery and the Rennline battery holder and am pleased with it. Just pop the hood, flip the switch, and done. I haven't had any problems with it.
Since it's not for racing, I just installed the two-pole switch. I suppose I could swap it out for a 6-pole later.
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 11-06-2014, 06:00 PM
