Ds1 Ds1 is offline
1 pound 9 ounce Lithium Ion Battery, $122, how bad could it be?
Hey guys,
While doing some lightweight battery research I found this thread, where Steve Wong mentioned how his $67 lightweight Deka EXT14 had no problems starting and cranking his car, with only 220 Cold Cranking Amps and 12 Amp Hour capacity: Light weight battery question.
That battery weights 12 pounds (see specs here: Deka ETX14 Battery)
Then I thought about a lithium battery, and found this one for an amazing $122 with similar specs... 240 CCA with 9 AH. But here is the crazy part... its weights 1 pound 9 ounces. Antigravity Batteries YTZ7 8 Lithium ion Size Motorcycle Battery YTZ7S | eBay
Do you think the Antigravity battery would be fine for a street driven weekend only driver 911 with a 3.2? Of course I would use a battery tender (or quick disconnect), which I should probably be doing now on my "normal" Interstate, anyway.
Old 11-13-2014, 08:19 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Li batteries are a great concept, but have their own downsides, decide for your self.
Lithium-ion battery - Wikipedia, the free encyclopedia
Li ion batteries have torched computers and other consumer electrical devices, Pb acid batteries take a tremendous amount of mishandling, physically and electrically, my concern is will Li ion take the same? Boeing 787 had issues with Li ion batts.
http://en.wikipedia.org/wiki/Boeing_787_Dreamliner_battery_problems
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-13-2014, 08:26 AM
Project Addicted
They do say good for an everyday 550cc moto. This is quite a bit smaller than 3200cc. I have a Shorai in my Duc and it does fine with a 1198-12.9:1 compression ratio engine BUT once the temps drop down into the mid to high 30's it goes dead. They are very temperature sensitive to performance. So beware that if may get you started but if it gets chilly, it may not get you home....
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 11-13-2014, 02:21 PM
Elombard's Avatar
that is just amazing. Ok ok they can double the weight and then will it work?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 11-13-2014, 02:38 PM
We are using one in a Jeep Wrangler based Ultra4 racer to start a 5.7 liter Chevy LS1. It's a motorcycle sized battery, but it works very well. Had a PCM problem in a race a couple of weeks ago and it cranked and cranked the big V8 as we tried to start it. Sure is small and light.
Old 11-13-2014, 02:49 PM
DG624's Avatar
I would go to their 6lb battery with more power...costs more but will not wear out as soon. I have a 17lb Braille but it is constant need of charging. Sometimes weight is good especially in balancing the rear weight.
Old 11-13-2014, 02:56 PM
Ds1 Ds1 is offline
Do you know the specs of that battery?
I never drive the car in the winter, and its almost always in the garage overnight, so I don't think temperature would be a huge issue.
Good thing is if it doesn't start, the car will be a full 40 pounds lighter, so it will be easier to push and pop the clutch
Old 11-13-2014, 04:57 PM
A few people in the autox world are using the Ballistic brand battery (pretty much the same thing, different case) in Miatas / Hondas. I hear they're not super reliable, and they carry a spare with them to events just in case. But just look how tiny they are!
I'm thinking of going compact AGM for my car. Partly for the reliability, partly because if one quits away from home my local Wal-Mart has something of the same size sitting on the shelf, and partly because the voltage regulator on our alternators is notoriously flaky. I don't think that works well with the LiFePO4 chemistry.
Matt - 84 Carrera
Old 11-13-2014, 05:10 PM
Mike Billings's Avatar
I'm trying a Braille lithium battery next. 13 Amp-Hours, 6.4 Lbs
https://www.braillebattery.com/index.php/braille/product_batteries/gu1r
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 11-13-2014, 05:24 PM
agm in the sc for 2 yrs now.
no issues.
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 11-13-2014, 06:54 PM
Max Sluiter
Flieger's Avatar
Boeing 787 Dreamliner battery problems - Wikipedia, the free encyclopedia
There are many different Lithium chemistries. Lithium-Iron-Phosphate batteries are inherently safe and don't need the complex temperature monitoring system like Lithium polymers do. In fact, when I worked on an electric FSAE car you didn't need any firewall between you and them, just some insulating material. If you ran LiPo's you needed a full firewall and insulation. We didn't run any temp monitoring on the LiFePo4's, just the charge balancers to prolong their life and capacity.
Old 11-13-2014, 07:04 PM
RETIRED
Joe Bob's Avatar
My yellow top Optima just died after 14 years.....$200 out the door. Ooof....
2012 ML350 3.0 Turbo Diesel
Old 11-13-2014, 07:48 PM
Walt Fricke's Avatar
Isn't it pretty silly to fuss with battery weight for a street car?
Now a track car, where shedding pounds is the name of the game, that is something else. Plus you seldom need to start a very cold engine.
The little battery (not Lithium) I have in my SC for track use, which worked fine for that as long as I was careful, would not really turn over the motor today at 15 degrees F.
Old 11-13-2014, 11:39 PM
tazzieman's Avatar
That extra 11 pounds of polar moment up front might save your bacon on the limit in a tight curve
Lithium is good for bipolar moments. I'm staying with last century technology!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 11-14-2014, 12:03 AM
oh snap's Avatar
I just replaced a battery and came to the same conclusion. Thought about going smaller and smaller. It doesn't make sense to spend more and risk reliability to save 10-20lbs when I have a radio, AC, heavy power seats etc. Settled sort of in the middle with a ~25lb sealed lead acid battery. A little nicer than the big mother that I had in it before but hopefully fewer compromises than the really small ones.
I do like to see people experiment though. Id love to see more people trying LiFEPO4 batteries in street cars to see how well they work long term.
1985 Iris Blue M491 911 Coupe
Old 11-14-2014, 12:14 AM
This thread certainly has my attention. I am willing to be a guinea pig and try a Li battery..amazing how light they are! Wow.
Old 11-14-2014, 06:36 AM
Ds1 Ds1 is offline
I guess I should've mentioned that my car is a lightweight no-A/C no-heat no-radio no-power seats kind of vehicle. Also my car has already been put away for the winter for about 2 weeks now. Maybe I'll just have to try one of these batteries in the spring. Match up the specs, get the $40 lithium battery tender, and see if I can conquer the world with 2 pounds of electricity storage technology.
Ds1 Ds1 is offline
I should also mention that Antigravity makes a ton of sizes of battery. You can get a MASSIVE 700 CCA and like 30 AH battery that weights around 6 pounds or so... But it's $400.
Old 11-14-2014, 06:38 AM
Ds1 Ds1 is offline
Sorry for the multi-posts, but check this out. That Ballistic battery that Driven mentioned is $133, weights a tiny bit less than the one I posted, and has better specs: 15AH and 275 CCA. The website also claims no trickle charger required since it only looses 10% of the charge in one year of static use. Interesting.
Ballistic Performance 8 Cell EVO2 Battery - RevZilla
And the 12 cell is only a little more $ and has a whopping 410CCA and 20AH at just 2.5 pounds. Ballistic Performance 12 Cell EVO2 Battery - RevZilla
Old 11-14-2014, 06:43 AM
Elombard's Avatar
Awesome. I know its rediculous to worry about a few pounds in a mostly street car but I love the technology and its part of the fun.
Old 11-14-2014, 07:04 AM
