Banned but not out, yet..
RSBob's Avatar
If that part is so far gone, I can't imagine the house of horrors in the inner and outer longs, rear parcel shelf, and and....... I would walk away.
Old 11-14-2014, 08:31 PM
Straight shooter
Lapkritis's Avatar
What fun is there in walking away? Dive in there, chop it up and weld in new metal.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 11-14-2014, 08:36 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
this is avery common area. it rusts out under the left dash, it can wreck a few gauge holes and most likely, beneath the pedal cluster(the pedals) it got down there too as well as the front and bottom section beneath the fender mounting. It could be not as bad elsewhere or a disaster. we need clear and more photos to help you at all and can't make decisions on one grainy close up of a very common area to rust.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 11-14-2014, 09:26 PM
RSBob's Avatar
The way OP phrases his questions, he will more than likely have the repairs professionally done. That starts adding up to serious coin if more areas are found.
Old 11-14-2014, 10:27 PM
I wouldn't touch it. If it was a long hood, maybe.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 11-15-2014, 04:44 AM
schoward's Avatar
No run for a long time - and electrical issues way back when too. On top of that rust. Move on. You can buy a good shape sc for what you will put into that car in first 6 months.
Scott
1981 911SC Targa - Platinum Metallic
Old 11-15-2014, 06:48 AM
Not the case. Just sayin'
Again, thanks to all for your input.
Wayne
1980 911 SC
1960 MGA 1600
Old 11-15-2014, 07:15 AM
