Where does the ground strap attach to the alternator
I bought this 3.0 with the engine harness already removed and now I'm having trouble figuring out how to wire it back up. I think I have the brown, blue and red wire correct, but I have a braided line that connects on one end to the case. Where does the other end connect?
Old 11-16-2014, 07:25 PM
Braided ground cable connection.......
If my memory serves me right, I think it's connected to one of the studs holding the air diverter. The ones (studs) shown in the picture (alternator fan housing).
Tony
Old 11-16-2014, 08:30 PM
76 911S Targa
Tony is right. It will only reach the closest stud so there is no confusion.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 11-16-2014, 09:27 PM
Here is the only photo I have. The ground strap is currently disconnected in this photo but it was bolted onto the lower stud that the fan diverter was connected to.
Old 11-16-2014, 10:38 PM
It is connected to the 6mm stud that is coming off the diode pack
It is a 10 gauge brown wire not a braided strap The braided strap was used on earlier engines
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 11-17-2014, 04:36 AM
Send a message via Skype™ to Porboynz
I disagree, that diode pack stud is at 12V positive, note that both studs are labelled B+. It should go under one of the fan shroud studs with suitable washers to ensure a good connection. It provides a better earth connection from the body of the alternator to the engine than is provided by the metal to metal contact provided by the retaining strap around the fan housing.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 11-17-2014, 10:55 PM
Thanks, The connectors on the ends of the braided line would support the connection to the bolt on the case.
Old 11-17-2014, 11:03 PM
