removing auto heat wiring loom questions
I am backdating systems and trying to remove wiring on my 1985 targa. I removed the auto heat controls between the seats. I have the two connectors under the cardboard panel. The wires go in the tunnel and most likely forward. Has anyone successfully removed these?
Also, there is a small gauge brown/white wire running back under the ebrake mount plate. What is this wire for?
Thanks-
Old 11-22-2014, 02:51 PM
brown wire is for the red e-brake warning light in the middle of the dashboard
Old 11-22-2014, 02:59 PM
Thanks, I am removing that too.
Old 11-22-2014, 03:44 PM
